cut 16.9s, M Alyward
42Farmall
01-17-2007 19:51:04
What bar height should I leave when cutting a set of 23 degree 16.9 x 38's on a 70 horse H Farmall? Running 4 and 6 mph classes 4000#
Mike Aylward
01-17-2007 20:21:18
 Re: cut 16.9s, M Alyward in reply to 42Farmall, 01-17-2007 19:51:04
If you are running that speed I probably would not go much deeper than about 5/8 of an inch, and that might be plenty at that. As a rule, the faster you go the less bar you need (or want). Hope this helps. Mike
42Farmall
01-18-2007 19:20:35
 Re: cut 16.9s, M Alyward in reply to Mike Aylward, 01-17-2007 20:21:18
Thanks.
