JD 70 head work
bassndeere
01-23-2007 18:48:01
Hello,
Can anyone recommend a good machine shop to rebuild/port/polish 2 cylinder heads for pulling.
Thank you
DSK
01-23-2007 20:10:17
 Re: JD 70 head work in reply to bassndeere, 01-23-2007 18:48:01
You can try Paul Marlatt in Rushville Indiana. He does lots of work on performance antique heads of all makes. He's one of a few that actually has a flowbench to check his work. Has some good running tractors out too. 765-938-2227.
Mopar-Harris
01-24-2007 09:56:56
 Re: JD 70 head work in reply to DSK, 01-23-2007 20:10:17
Murphy's Motor Service, Jeff Asbury. Jeff also uses a flow bench and recently acquired the rights to Jerry's Welding & Machine heads and cylinder blocks.
730-LP
01-26-2007 20:13:36
 Re: JD 70 head work in reply to Mopar-Harris, 01-24-2007 09:56:56
Mopar Harris would you please e-mail me I would like to talk to you about building a 6 cylinder flat head dodge. I can't get an e-mail to go thru to you. thanks send to surberwayne@netscape.net
