Re: Re: MW for Super M
Hayne D. Matthe
04-29-2002 03:54:05
Thanks for the info, how much stroke can you go with the stock rods? I am not sure what pistons I have but I ran a compression check and it read from 160-165 psi. This is with a gas head. The tractor was on LP, now it runs on gas. I have been told that it most likely has some aftermarket pistons to have that much compression.
randy hall
04-29-2002 10:07:21
 Re: Re: Re: MW for Super M in reply to Hayne D. Matthews, 04-29-2002 03:54:05
you can go to 6.5 using your stock rods but you will have to do a lot of clearance grinding.
