c farmall more power
bm3501466
01-27-2007 17:19:16
What can you tell me about the C farmall? What do they weigh? How many HP? Sleeved or sleeveless? What is the biggest IH motor that shares the same bell housing pattern as the C? Thanks guys for your help.
Jon B. in AR
01-27-2007 19:41:11
 Re: c farmall more power in reply to bm3501466, 01-27-2007 17:19:16
I still run the 113ci engine and do pretty good with a slightly larger carb and govenor turned up alittle. It's not a second gear puller but the taller tires help it get down the track better. The C-153 engine would definitely help it.
bm3501466
01-27-2007 20:23:17
 Re: c farmall more power in reply to Jon B. in AR, 01-27-2007 19:41:11
What does a 153 come out of?
RichH
01-28-2007 08:17:24
 Re: c farmall more power in reply to bm3501466, 01-27-2007 20:23:17
Small IH combines and the Farmall 504.
Jon B. in AR
01-28-2007 06:41:02
The C-153 engine was designed for industrial purposes. I have seen them in power units and generators. I am not sure what other tractor applications there are.
Shaggy
01-27-2007 19:14:44
A C-153 will fit with out any hassle but there are a few guys on here that have some pretty hot Super C"s that run the stock block.
I am hoping to give them a go at the Tallmadge pull with my Farmall B.
Shaggy
Charles McNelly III
01-28-2007 13:45:47
 Re: c farmall more power in reply to Shaggy, 01-27-2007 19:14:44
What all have you done to the B Shaggy? How do you get traction with those little tires?
Shaggy
01-28-2007 14:07:22
 Re: c farmall more power in reply to Charles McNelly III, 01-28-2007 13:45:47
The motor is just a Tisco overbore with a dome and a pretty good head. As far as traction goes I will be probably hurting in that department. But it just might help me since I only have 123 cid. Shaggy
CLIFF S
01-28-2007 17:20:46
 Re: c farmall more power in reply to Shaggy, 01-28-2007 14:07:22
And CLIFF S To Help! Shaggy If we had Extra time out there i would bring ya a set of 12.4 tires off my Allis C!!! I know they would help ya!!!
t.r.y.
01-28-2007 17:15:27
Hey shaggy we'll probably be meeting you for the first time in tall, oh. I pull a 230 divison 2 3500 I would love to be in the 3250 div. 3 but my tires would really kill me there. oh well. Cliff s told me a little about your B. Can't wait to see it. Only a month away can't wait. see ya
Charles McNelly III
01-28-2007 18:31:28
 Re: c farmall more power in reply to t.r.y., 01-28-2007 17:15:27
Hey Shaggy, I pretty much have the same set up as you. I run 9.5 x 24 rears and need more tracton. I pull in the 2,600 lb. and 3,100 lb. class. I don"t motor out, I run out of tracton. I was thinking about going to the 11.2 tires but I need to stay under 3 mph or I would be pushed up to another div. I can"t see myself pulling this tractor in the 3,600 lb. class but time will tell. Good Luck with your B, I"m real happy with mine.
Charles
Shaggy
01-28-2007 20:33:26
 Re: c farmall more power in reply to Charles McNelly III, 01-28-2007 18:31:28
I have 11.2x24's on my B now and the few times I have pulled it it has done pretty good.
This past year I pulled at a show and it was a loose track and my buddy with a Demo C beat me by 3ft but he had a CHEATER wire on the gov and I was turning 1800 rpms. I'll get him this summer!!
Shaggy
Shaggy
01-28-2007 18:27:27
My Poor B isn't much to look at but it runs pretty good or at least I think it does! All I need to do to it is get rid of the pto and hook up the kill switch and I am ready and maybe borrow some weights if I can 't come up with some here. I am going to try 3500 on Sunday! I'll see you guys there! Shaggy
CLIFF S
01-28-2007 19:50:56
 Re: c farmall more power in reply to Shaggy, 01-28-2007 18:27:27
With a 20 inch Draw bar you will get bite But i wish you had some 13.6 x 24 tires on it! To help your bite and keep your speed up to 3.5 mph! Thats why i said about my 12.4 x 24 tires off the Allis C because there Taller and keep your speed up better!
t.r.y.
01-30-2007 16:53:38
 Re: c farmall more power in reply to CLIFF S , 01-28-2007 19:50:56
I have a few extra weights you can use. Mostly all ih 75's and 100's
