Pistons...
BushogPapa
01-30-2007 22:44:53
Well, I have my new set of pistons roughed-out.. I turned them on the wood lathe... This time I used IronWood for them..should hold up much better than the ones made out of pine, I made last year...! I left a real nice dome on them, so when they start to burn up, the compression won't drop off as fast... They sure are nice and light..!! The combine used wood bearings in the walkers, so I guess the wristpins will be just fine, too...!! FWIW...!!! Ron..
dboll
01-31-2007 10:06:46
 Re: Pistons... in reply to BushogPapa, 01-30-2007 22:44:53
I thought about coating the cyl. walls with crisco then spraying in expanding foam sealant to make a really light set, haha!!
