4010 weight
algar
02-02-2007 22:20:05
What do you have to do to 4010 to get it to pull 5500 with a 200 lb man?
tvman
02-04-2007 16:01:10
 Re: 4010 weight in reply to algar, 02-02-2007 22:20:05
algar send me your e-mail and send you some pictures and info about a 5500lb 4010 with weights and 240 lb driver
CrazyAllis Kurt Hamel
02-04-2007 15:31:11
A good story for you on that!I heard a guy ask how they got a tractor that light and the puller said it's easy!Just look at it through binoculars backwards and it gets so small it hardley weighs anything!
Lightweight
02-04-2007 05:51:28
Check pulloff.com. Dan Parks has parts listed.
tcoop
02-03-2007 08:47:04
I have seen a 4010 pull in a 5500 lb class with 2 weights on the front and a 200 plus driver. They removed all unneeded drive gears, PTO, and Hydrolics in the transmition. Pressed steel wheels. replace the frame with aluminum, all alluminum wheight brackets, light weight radiator, get an after market fiberglass hood and replace all sheet metal with aluminum, make the deck and seat brackets out of aluminum, replace the front axle with a light weight front axle. I would guess there tractor weighs in at slightly less than 5000.
seen one
02-04-2007 06:10:05
 Re: 4010 weight in reply to tcoop, 02-03-2007 08:47:04
seen one in the late 60's 5000# diesel
