The 200 hp M theory,,,
ChadS
02-12-2007 09:14:37
How about using a dyno cell instead of a pto dyno to tune to the rpm instead of rated pto rpms? Where you only dyno the motor instead of going thru the tractor pto. You get to run, and focus on a totally new range, where, the rules do actually change a setup from one set on a pto dyno, and one set on a engine dyno. Do you think that things would be the same, or different? My old fashioned pto dyno technology, and the new age engine cell dyno technology is what happens when you take the tractor out of pulling and becomes drag race pulling. I still run thru the pto,, and that is a set rate rpm range to focus on, 540 and below, which in most cases, on a H, it would be at 1815 engine rpms, and below 540, 1815 and under rpms. 1815 engine rpms, at 540 pto rpms. The engine cell dyno, will let you run hp at actual engine rpm. Not gear reduction to have a set rpm range to work with, so its anywhere you want to run the rpms to. Lets say, your allowed to run 2500 rpms,, well, if your tractor, does not let you rev up to 2500 and be at 540,, then you cant accurately know what the hp is at 2500. Only, what ever the tractor's gear reeduction pto rated speed would I know the HP. 540 and below rpm is the range I am focused on. Common belief is, you rev up an engine faster, you will have more hp at the crank. True. all 6 cyl engine are based off this theory, rev em up turn em loose its free hp. Like I said, you cant measure that on a 540 pto dyno. So if you can measure the HP at a higher rpm, the numbers are alot more impressive, and a better condtions where the science will more come into play. And I think,,that is what your really looking for for information. Its not tractor pulling, when you take the tractor out of the equasion, Mr.Barenie. Show me one time, westville mafia ever had an engine on a cell dyno,, and we may see a 250+ hp 4 cyl moline! In our club!! I dont doubt it one bit. But, you put it back in the tractor,,, HAHAHA!!! And its probably 150 at best thru the pto. Id have a 150 hp H motor if I used a cell dyno instead of a pto dyno. Im not knocking any of it either!! But, Thats what they do in the future,, thats what makes the latest technolgy so desirable. My technology is "inframe tuning" Same thing as if they was to put a car with a big block on a chassis dyno,,, and run it thru the drive train,,, the hp is lower at the wheels, then at the crank,,, but, thru the dyno cell, engine all by itself,, and its probably 50-75 hp more. Darn pto dyno's!! HAHA! So outdated,,,, See ya! ChadS
LW
02-12-2007 18:27:29
 Re: The 200 hp M theory,,, in reply to ChadS, 02-12-2007 09:14:37
4 cyl Molines that make over 250 pto HP already exist, Yes, in the real world!
ChadS
02-13-2007 08:35:48
 Re: The 200 hp M theory,,, in reply to LW, 02-12-2007 18:27:29
No doubt. Chad
Mopower
02-12-2007 20:43:44
Give it to em' LW.
AW Puller
02-12-2007 16:13:57
Why cant you test an engine at any rpm on a PTO dyno? You can test at any rpm your little heart desires and using simple algebra skills, can convert the numbers on the dial to the actual horsepower number. If the dyno is capable of testing at 1000PTO speed, you could check your tractor at TWICE the rated rpm. Ofcourse, this method only works in reality where torque and horsepower are related. It may not work in chads land where you do and say whatever sounds nice and it becomes gospel.
How is reving a 6 cylinder up "free horsepower?" Its only going to be able to suck so much air into it, and when it runs out of air, its done....period. When it runs out of air, it cant make any torque, and if it cant make any torque, it will fall on its face.
Im attaching a link to help explain how horsepower and torque really are related to eachother. It even has pictures, that may help you to finally get it!!
ChadS
02-13-2007 09:16:55
 Re: The 200 hp M theory,,, in reply to AW Puller, 02-12-2007 16:13:57
On a pto M&W dyno, if your trying to read the HP at any reading above the 540 rating, it will show a lower number instead of a higher number. im not saying you cant put a load on the engine at higher rpms, but your tuning it by ear at that point. If the tractor is not equipped to run double the rpms, more of a safety aspect to low rpm parts at the rated speed. Id bet if it was hooked up to a cell dyno, with a computer readout, you could probably get an acurate reading of hp at above the rated rpm. Its still gear reduction thru the pto, anyhwere you wanna look at it. So if you can do the math configuration on the 140 hp AC,, lets have a look,, First off, which frame would the big engine be sitting in? If its in a WD, I can guarentee you, that engine is not 140 at 540 thru the pto, if its in a WD. More like 117.46hp at 1740 engine rpms, at 540 pto rated rpm. Put it in the D-17, it still would not be 140 thru the pto, more like 136.24 hp at 1995 engine rpms, and 540 pto rpm. See, unless you alter the pto gear ratio, the over rpms dont mean anything on a pto dyno. its all done by the factory to set that up.
On my 460 H,, I put a 6 cyl gas engine in the H rear end. we all know the 6 cyl dont run at 1815 engine rpms now do we? No, but thats what I have to go by on a pto dyno, H is rated for 1815 engine rpms at 540. You take know factors that do exist, and you can darn near get an accurate estimate of hp at the higher rpms. You can do it two ways,, Hp divided into 540, then multiplied by the new faster pto speed you want to know. In my 460H its 78 hp at 540 at 1815 engine rpms.
Here are the factors I want to know,,
I want to know how much HP my 6 cyl will make at 785 pto rpm (on the H pto)and 2640 engine rpms,, (Stock 706IH rpms)
78hp divided by 540= 0.144444 444 X 785 pto rpm = 113.38hp at 2640 engine rpms, and at 785 pto speed.
Thats just one math problem, here is another,,,,
hp divided by engine rpm X new rpm = hp at new rpm.
78 hp divided by 1815 engine rpms = .042975207 X 2640 (new) engine rpm = 113.45hp at 2640
So yes, I belive that there is a math formula to change over hp at different rpms with know factors taken from a pto dyno.
Try em both using those formulas with your known Hp at 540, or engine rpm. its donw with a calculator,, so its a calculated responce??? Chad
AW Puller
02-13-2007 17:41:56
 Re: The 200 hp M theory,,, in reply to ChadS, 02-13-2007 09:16:55
Where do you keep coming up with this stuff?!?!?!
Just where did you come up with the idea that you can check power under 540pto but not above? Find that little slide card that converts hyd. PSI to horsepower that came with your dyno. Then take some tape and cover up all the HP numbers on the dial so you wont be tempted to look at them. Then you can pull the tractor down to ANY....yes, ANY rpm above or below the rated rpm and use your little card that you found earlier, line up the pressure and RPM and wa-la, you have your horsepower reading. Should be easier for you than the math thing to try to figure out.
The pto gear reduction has nothing to do with engine horsepower. Engine horsepower is really what you are checking, right. I mean, what turns the tires, the pto or the engine?? Now for your physics lesson for the day. Power in=power out (assuming no friction) What this means to you is that in a world with no fricion, the power coming out of the engine into the pto gear train and the power that comes out of the pto gear train into the dyno are the same. The PTO shaft is geared down from engine speed. This increases the torque available at the PTO shaft. BUT...BUT the speed at which the shaft rotates is decreased by the same rate that the torque was increased, thus resulting in equal power levels. If a D-17 pto is geared down from a WD, all that means is that the engine has to turn more RPM to turn the pto at the same speed. It may deliever more torque to the pto, but it has to turn harder to get it there.
From looking at your little horsepower and rpm conversion formula, I see you STILL dont understand how horsepower, torque and RPM are mathematically related. Here in reality, you cant find the horsepower without knowing the torque. According to your math, your 460H would make 257HP if it could turn 6000rpm and not fly apart (78/1815=.0429*6000=257.85 Remember, that's YOUR math formula). Let me assure you, your 460 doesn't have 257hp. All that power without changing the carb or anything, thats pretty magical! Guess thats what you meant when you said just rev a 6 cyl up more and its free HP. Your math assumes that your engine makes the same torque from the first instant of crankshaft rotation to infinate RPM. Again, you can rest assured that your engine does not make 225.7 ft/lbs of torque from the instant of crank rotation all the way thru the rpm range. It may make it at a certain RPM, but not from practically 0 til she blows.
Horsepower=(RPM x Torque)/5252
Torque=(Horsepower x 5252)/RPM
I didnt make these formulas up. They are available in a number of books and websites.
Here are a couple more links that maybe will help you understand it. (Copy and paste)
Link
http://auto.howstuffworks.com/question622.htm
ChadS
02-14-2007 06:56:23
 Re: The 200 hp M theory,,, in reply to AW Puller, 02-13-2007 17:41:56
Aw, I appreciate all this. But Im gonna end it right now. at least on my side,,,, Point well taken, HP is HP at any given rpm,, that was not my arguement,,,,, I said, if he puts it in a tractor, and ran it thru the pto, and pto dynoed that tractor,,, he'd be disapointed. His advertized number would not be the same as what a rated hp check would be. It because the rated 540 speed, comes with a specific engine speed. and in this case,, its 1720, or 1995, not 2050. No doubt in my mind, that its 140 hp at 2050, but its not 140 at 1720, or 1995,, where the average joe would use methods of testing of the pto. A real world method, primative, but a method none the less. The modern methods,,with using on the engine, is new technology to the tractor industry for antiques. They make up the rules as they go along, such and such hp at a higher rpm than what stock is,,, WOW,, thats big HP!!!! But drag it down to the normal levels, and find out,, its not much more than what we imagined. Even if you checked the engine only at rated rpms, its still not gonna match up. I dont care which method is better or not,,, I would not go about saying what they are doing is wrong,, but should be more realistic with the method description of how they got what they got, instead of hiding the fact behind a bunch of math, science, and long winded words, when all they had to say was,, we dynoed the engine out of the frame,, where the rules are not the same as if it was in a tractor chassis. So pay attention,,, right?? they never came here and said anything like that,, they just jumped in and said Im full of it, and then go preachin,,, well,,, if they would have explained the whole thing from the git go, I wouldnt have to be here battling the two methods pf obtaining HP readings. Then, I can learn too and not have to take such a beating just cause I do it differently than what popular demand is, or not is, or what have you. Ill read all that literature, the minute you tell me how and why the HP he announced, is not the same as going thru the pto. or checking the HP at rated rpms. You tell us that, and Ill jumpthru any hoop you want me to. Till then, im like that stubborn dog that wont fetch a stick, even if it had a steak tied to it. Chad
Kurt Hamel
02-15-2007 18:22:11
 Re: The 200 hp M theory,,, in reply to ChadS, 02-14-2007 06:56:23
If you want the whole story the motor WAS dynoed on an M&W PTO dyno.Now if you will look closely and possibly read the manual that came with the dyno you will discover it has TWO drive shaft that come out the front of the dyno.One is for PTO and the other for DIRECT drive.You still owe me the buck,at 2250RPM it makes 162HP.Now that is derived by a pressure reading of 1850PSI at an rpm of 2250 or 630 pto,you will notice TWO RPM scales on the tach,You then use the M&W Hydra-Gauge dynomometer Pressure-Horsepower Conversion Calculator, these are still available from M&W if you need one, and that is how I arrived at the above mentioned HP. Also, Chad, if you will check University of Nebr. Tractor Test results you will find that NO WHERE is it stated that the max horsepower was derived at 540 pto rpms.Ever wonder why most ractors run an ENGINE rpm that is above the rated PTO rpm. Now Chad how in the hell do you think the pto on WD Allis would remotely handle that kind of power?Catian Hookerous told me that at around 100 the pto on a WC will BLOW right off!And since a WD's pto isn't much stouter I didn't even try it.Beside my tractors don't have pto's anymore. That motor made 150HP at 2000 and still has 146 at 1800.This figures out to 378ft/lb of torque at 2250rpm,393.75ft/lbs @ 2000,&425.83ft/lbs @ 1800.These figures are the result of the math equation that torque=HPx5250 divided by RPM. These are REAL figures from an M&W P400B dyno.The gauge is less than 2 years old and the tach rpms were backed up by an Autometer impulse tach that gets it signal off the flywheel teeth, not the ignition system. If you have noticed the HP was dropping as the engine rpm came down but the inverse is occurring with the torque.I don't think you will find too many people that will think 425ft/lb of torque at 1800rpm from anything other than a diesel,especially a 400cid gas, is too shabby. I have an extra copy of an owners manual for the dyn if you need one. Have you stopped to think how the dyno can be used as a direct drive or a pto drive? Thats correct, a gear drive.NO I'm not taking the tractor out of pulling,I think if you don't take the time to go throught the rest of the tractor and don't know how to set it up you can't win.I'm just saying that PTO hp is no different than engine power when taking into consideration the parasitic losses of friction,oil drag, etc. I gather you don't use the slide rule thing or you simply refuse to if the only power readings are at 540 pto. Don't you ever work on newer tractors with 1000 pto's? It would be affully tuff to have dynoed the 4840 we just OH'd and been able to derive any HP reading if I was stuck on 540 only.Just My Honest Opinion. Kurt Hamel Hamel Repair AKA as CrazyAllis
ChadS
02-16-2007 08:32:13
 Re: The 200 hp M theory,,, in reply to Kurt Hamel, 02-15-2007 18:22:11
Kurt, I came up with different numbers,,, BUT,, before you say no way,,, hear me out. See, when I do my little math conversions, I took Hp divide by rpm to get the HP at the higher rpms.. Thats works when your trying to calculate hp at the higher rpms,,, now, the problem I ran into is that when I run the numbers to go below the 2050 rpms,, it comes out lower estimates. Then, I got to thinking,,, I cant use that formula to go below the test rpms, so I have to change it. So here is what I came up with,,, this is if you went by how the PTO guage works,,, ifyou put it on the dyno in the 17,,, 140hp at 2050. I had to swap the math around to do this, but it makes more sence to me at this time,,,, so it looks like this,,,,,
140 hp at 2050, thats 554rpm on the 17's pto,,, if 1995 is 540 for the 17.
ready for this??? Im not, cause I have to now send you 2 dollars.
Mind you, this is if you was to go thru the pto, and understand what I would see on my guage if I dynoed your tractor.
it may show, 140 hp at 554, or 2050 engine rpms
143.85 hp at 540, 1995 rpms
at 465 pto rpm or 1720 166.84 hp
at 406 pto rpm, or 1500 engine rpm,,, 191.33 hp.
I asked my self, if I checked the hp at 2050 engine rpm on a 540 dyno it would show less at the higher rpm, just like I mentioned,, lug it down lower, and the HP increases, due to increasing HYD pressure. Right? Right. So, I changed the formula to look like this to figure out from 540 and below instead of 540 and above,,,,
HP at a known rpm,,, 140 at 2050.
Take 140hp X 2050 rpms = 287000, then divide that by the lower rpm, I took it to 1995 so it looks like 143.85 hp. The rpm drop now concludes with the increasing hp from more hyd pressure it takes to lug the tractor down harder. Now thats at the 17's rpm range,, not the wd's,, Keep on dropping the engine rpms, and figure out what the pto speed would actually be, and thats what it would be at the low side of the rpm using a pto dyno. So, congratulations,, if you wanted to go by the 1500 engine rpm estimate,, or 406 pto rpm, you now have the first 191 hp AC 4 cyl engine. According to a pto dyno. But at 540 inthe 17, its 143+. it wont be as high in the wd chassis due to different rpm,,
Also, on a 540 and below pto dyno, I consider the peak hp reading at the lowest rpm till the hp drops off, is what I call a torque curve. It can show you how much more pull or torque out have put into your engine. At some point the rpms will eventually overcome the setup and drop like a stone,, but if you get over 25 hp on the torque curve below the 540 reading, you got an engine that has a really long torque curve in the basement rpms. Its not dyno spiking,,, what I usually do is drop it to 440 pto rpm, that way its a baseline limit, so I dont get tempted to do anything below that. From 540 to 440 is the area rpm I focus on to get more out of it. The math compared to actual dyno numbers is within a margin of error so it can be quite accurate.
As for if I ever dyno anything bigger that needs a 1000 pto? No, biggest Ive ever had on the dyno was a G moline, and the smallest was a Super C IH,,,
I would love to try to use the direct drive off my dyno,, I would have to build a stand etc etc,, but till then I back the ol mule up and twist its tail. its what the customer, or I have to work with at this time. So, if you can understand what Ive said, and Ive learned from what you have all said, (except for the Real puller)
One last note,, any stock tractor that Ive ever tuned or checked on a pto dyno, Ive had to turn the rpms up just to get to 540, so no, they did not over rev them from the factory, remember, they were afraid of em back then flying apart, so they played it safe. it was all based off of rated rpm, but I dyno them from above the 540 and pull it down to the 540 rpm. the carb is open more, its woke up and more ready to pull it down, instead of going up to the mark and pulling down from there,,, I find more low end power that way. So, how would you like your payment??? ChadS
AW Puller
02-14-2007 11:03:59
I think what is still confusing you is that you are stuck on the thought that you have to check at 540PTO and only 540PTO. Cover all the horsepower numbers up on the dyno so you can only see the hyd. pressure. Take your readings at whatever speed you want and use the slide card to find the horsepower. Take your results and convert the pto RPM to engine RPM. Do that using whatever chassis and pto combinations you want, and however many different combinations you want. Minus slight differences in friction in the various PTO systems, the results are going to be the same. Remember, you get just as much horespower out of the pto as goes into it right out of the engine (minus slight frictional losses). Power in=Power out.
You want me to explain how this 140HP isnt the same as going thru the pto? You must not be listening, because 140 engine horsepower, minus frictional losses, IS 140 HP at the PTO. When you figure out that there is something other than checking at rated RPM and that it is possble to check at any RPM accuratly, you MIGHT be able to figure this out.
I am running out of ideas on how to explain this to you so it makes sense. Im trying hard to be nice here, but its not fair to people to get misinformation because you dont want to undestand math and science. When you take your blinders off and see the real world or quit spreading misinformation, then I will quit preaching to you.
ChadS
02-14-2007 16:37:01
 Re: The 200 hp M theory,,, in reply to AW Puller, 02-14-2007 11:03:59
K, according to the article he wrote about this engine, it was 140+ at 2050 engine rpm, on an engine cell dyno. Ok, I will finally say its 140hp,, AT,,, 2050 rpm. Rated rpm, for tractors, is a governed speed, set by the tractor makers. Nebraska testing used 540 or 535 pto dyno speed to check for the HP for that make and model of TRACTOR. Whatever the engine rpm is, the tests were done at 540 or 535. I guess in other words,, thats tractor mechanic lingo, because, back then, thats all they had to go by. For me as a Tractor mechanic, I must follow suit and still base all my research off of the same path, our founding fathers had done so many times 50+ years ago. 540 pto. Im playing with tractors, and engines so I dont have the luxury of only using one. Im just following suit. Im not blind to more modern methods though,,,,, ,
I have a stack of Hot Rod magazines 2 feet thick, and everyone of em has some sort of article of an engine build up,, more power!! More power!! read all about it. They take the engine out of a SS Chevelle, or a Hemi Mopar, and they put on the engine dyno,, and they tune it, dial it all in, record the numbers for the highest readings, and that becomes public knowledge,, or bragging rights,,, Right?
Then the owner of said machines, put that engine in a car, truck or whatever,, then, they decide to put the whole car on a chassis dyno, to test power at the rear wheels..... ...
Well, Im a fan of the powerblock shows on Spike TV,,, and I see that show called HP TV,,, They have one of these chassis dyno testers. Ive heard that guy say time and time again, the engine would be alot stronger in HP results, if it was not going thru the drivetrain. So, does that mean that there is not said HP going thru the wheels???? Not thru the wheels,, no, at the crank yes,,, and the beaty of that statment, is that they choose the rpm varying ranges,,, not set by a governor.
You asked me if the engine made 140 hp atthe crank, is it present at the pto, or wheels,,, Yes, and NO. The yes part of the argument is,, at 2050 rpm the engine made 140+ hp. But, what is it at rated tractor rpms?? 1720 rpm is for a wd, and 1995 is for the 17. No question in my mind, at 2050 engine rpms, turn on the pto,, at 643 pto rpms, it would be 140 hp, if a pto dyno would show that without the card conversions. No Tractor dyno will let you do that, without the card sheet conversion,,,, So here comes the NO part of the argument,,,,,
Tractor chassis are set for a specific rpm range for 540 pto speed. Unless, you regear the pto to run slower,, you cant get away from 540 and the set engine rpm. Since we are talking about a Pulling TRACTOR,, the stock chassis had a pto at some time in its life. So a 540 reading, sometimes is all we have to go by, and the proof of that is, whats available,,, tractor dyno's are bout on every street corner repair shop, so,,, back it up and hook on.
Reguardless of what the engine dyno says,, the pto dyno is going to tell the story of what it is in tractor terms. The pto dyno, in my opinion works in opposite of what an engine dyno works. One, the pto dyno reads hp higher as rpm drop, anything above 540 is irrelivant in tractor terms
becuase without the cheat sheet conversion to read higher rpm ranges. The pto dyno does not read it. 540 is where the tractor dyno test is read at. Two,,, the tractor dyno, does not care what the HP is at 2050, its not capale of reading that rpm,, unless thats what the engine rpm is at 540. , but it will be a lesser reading,, the 540 hp reading will always be higher that 550, 600, 675. 540 and below, the HP numbers go up higher than what it would read at 675 or what ever 2050 was,,,, So, according to the pto dyno,,, the lower the rpm, the stronger the engine. What do I know, using tractor terms?? Simple, I took real world knowledge,, 140 hp at 2050, and converted it to if was read at 1720. I told you already what I belived it would be,, only thing i did was slow that engine rpm down to real tractor terms. 117.46 hp at 1720 or 540. If it was 140 hp at 2050, the pto dyno will be a lower reading everytime. its not that the 140hp is not present,, but its not present at stock rpm,, at least according to a tractor dyno. its there when it hits 2050,, but not at 1720. Thats just the way it is in the tractor terms. Thats all Im saying.
I appreciate the time and effort your doing to help me understand what your talking about. Trust me, I know what your saying, but, understand,, even though we do what we do to tune the engine, as far as what to do is the same, the two dyno's will read differently everytime. its something your gonna have to trust me on,,,,, , if you want proof of my theory,,, if anyone has an engine dyno setup to dyno a IH H,, Ill be more than happy to bring my engine to a engine dyno cell,, read HP at 1815, and what ever rpm range im allowed to run,, or what ever rpm range the best HP was made at. then, we will put the engine in the chassis, and run a pto dyno tractor terms test. I promise you, if the Best HP was made at a higher rpm other than my rated rpms,, it will show less everytime if its pulled down to 540.
See, its more of a trick to keep tractor builders honest, because we can check the work,,, we do say you get x amount of HP at 540,,, and trust me, they check em,,, using that pto can keep em all in a line,,,,
Using the other dyno,, even though its not a tractor terms hp test,, its a way to break away from the pto hp estimates given by quote, or promise,, but if the buyer was smart,, thed ask for the HP to be checked at tractor rated speeds. or simply state,, they dyno the engine by itself and go by that. its the customers choice at that point,,, but we keep it the old fashoined way,, keep it real, keep it tractor,, keep it honest.
Its up to the builders discretion on how they report their HP, and if they know there is a difference in the readings,, they should report it. LW done just that when he dynoed project M,,, he said his water brake dyno will be different from a HYD fluid dyno.
I have no problems with any technology that follows engine only dyno tuning,, but when they try to pass it off as tractor hp,, its not even tractor related.
I know, Ive said this over and over,,, and over,,, but, there is a difference. Now, if you want to explain the differences, pick an engine and go with it,, I have a H I love to show the pto dyno and the engine dyno difference. Id like to know what peak hp I can really get at 2500rpm out of it.
How do I do that, and is 150 hp possible out of a H?? Ive seen 130 on a pto dyno from that H,,, sooo,, what would it be at 2500? Then, my bragging rights shoot up even higher.
Hope I did not tick you off here,, its a trick all us farmers/tractor mechanics use to keep the big money builders in an honest hp quote. Trust me, your not the only one Ive showed this to,,, my machinist buddy did not know either till I showed him. Hope to get into some good discussions on this new tech,,,, Im just old fashioned, but a younger fella. Chad
LW
02-14-2007 17:00:43
 Re: The 200 hp M theory,,, in reply to ChadS, 02-14-2007 16:37:01
I'm quitting after this your heads just too hard! Look Burn your M&W dyno sell it or somethng get you a taylor, 0 to 1200 rpm on the input shaft can measure the same. Upto 5,000 rpm on the engine shaft. PS When I drag raced we had a engine that made 530hp at the flywheel, At the rear wheels it made 380hp DUE TO FRICTIONAL LOSSES!!!!! !!!!! !!!!! !!!!! ! I:E: Going through transmission , coverter, Driveshaft, rearend differential. Do you get that? And yes you will have a slight loss in a tractor but you are only going through th constant mesh on a lot of trannys, With live pto your right off the engine with 2 gears to reduce to pto speed.
ChadS
02-15-2007 07:40:12
 LW,,,, in reply to LW, 02-14-2007 17:00:43
Your one heck of a mechanic LW,,, Im gonna let the info you and AW left and let it sink in for a while,, Hope I did not upset you too much. Good to talk to you though!! Chad
Yep, got it.
02-14-2007 17:11:13
 Re: The 200 hp M theory,,, in reply to LW, 02-14-2007 17:00:43
Thats the difference!!! Thats all Im sayin! Drag, gears turnin, in the chassis. Change the common belief on how tractor engines are dynoed and will go along with everything! Is brake HP the same as pto hp? Chad
LW
02-13-2007 18:11:38
You are doing a fine job of being a patient teacher! To bad your student has blinders one!
ChadS
02-14-2007 10:05:56
 Re: The 200 hp M theory,,, in reply to LW, 02-13-2007 18:11:38
Blindfolded, with a cigarette waiting to be shot. HAHAHA! Look, Im not trying to be a SOB here,,, really! if anyone can show us the way, I belive you can. You have been using your water brake dyno for how long now?? Can i pick your brain for a minute?? if you was to take your big moline engine, and dyno the engine separately, away from the tractors pto. You have the ablility to dyno tune that engine at a different rpm range right? I mean, your not just restricted to a stock rpm reading, or 540 readings right??? And if that is true, that could possibly mean, that the HP can be higher than what your 540 test would be?? I will admit, that that the new method of dyno tuning is great, if ones equiped to do so,, you get to focus and tune a whole different rpm range, so, power and torque levels would be higher than what is read at 540 pto or engine speed, if it was tuned engine by its self? Shoot, you could be able to say that that same 250+ hp motor can be actually 300 hp and selling yourself short on advertized HP??? NAAA,,, your just testing a new rpm range, to give you that higher hp result. Which is good, if your allowed to run that rpm range. But,, what if,, you cant run that rpm in a club,,, then, will the tune be the same as if you was to pull it down to stock rpms? Now mind you,,, the new method, is tuning for high rpm power,,,, not stock. I cant get by the reasoning,, by saying, that the tune specs will be exactly the same. Thats one issue Im dealing with, and need an explanation if one would provide that info. Id love to be brought up to speed of engine dyno tuning VS going thru the pto,,,,, I belive its the old and new technology method differs, surely even you can understand where Im comming from. Yeah, we know, Lead a horse to water, but cant make em drink, but,,, we try to drown them by trying. So, if the new technology is dying to get out in the open,,, somebody should educate us all. I for one would like to learn, but already have an idea,,, Im all for new stuff, but the old ways will not die off,,, but, we know there is a difference. So Ill start peeking thru the blinders if one has the answers that applies to our tractor pulling. Chad
eastcoastpuller
02-18-2007 08:12:52
 Re: The 200 hp M theory,,, in reply to ChadS, 02-14-2007 10:05:56
I have been all over U.S. to alot of tractor pulls. If you have ever seen L.W."s Moline pull.
You would say he knows what he is talking about.
Lots of people talk about how much horse power than can build, most of it is horse sh#t. I have seen his, and have not seen another like it.
LW
02-14-2007 16:33:09
Look I am going to make a attempt here,I am not attacking anyone! But the theorys you post could not be farther in space then the moon! AW Puller explained to you to the T how HP and TOrque are related and with a rpm and Hp or torque reading you could find the other.I have a engine dyno that is only a engine dyno, I have not had time to set up. My PTO dyno has a engine shaft on it,I don't have the same issues as the hyd. M&W.there again thats where the slide rule comes in. You can test at any rpm. Your theory on Heavier flywheels and free HP from turning more rpm are WHack! Sorry but true!~ So here goes, THis is how I tune a engine Could care less what rpm it pulls down to! I put a O2 sensor in the exhaust on all th LPs to monitor with, Gas I pull to the same water input setting everytime, Basically I open the gate wide open I vary the exhaust opening depending on how much hold back I need and then look for a increase in engine rpm and power, IF I hold a higher rpm and or make more power I am getting where I need to be. I don't worry about HP numbers to much, I just want it doing all it can. I do no there are lot of claims on HP that are way off, I check behind and never get what the others say. Of course Thats irrelevant. YOu can spike a dyno by shucking the input wheel, but its not a real reading. You can keep believing what you want but your only holding your self back from learning how things really work,Do you want to know why farmall Increased the weight of the 450 flywheel? Because of the live HYD. So when a tractor was at low rpm and some one demanded on th HYD the engine wouldn't get pulled down and the gov. could smoothly respond. Because these engines were low power work horses the heavy flywheel made it smoother.Stock tractors I dont't mess with the flywheel weight, ANthing going fast, pulling a big gear trying to take off in a big gear and get rolling I lighten all I can, My personal 6 cyl Moline has a 50lb flywheel, It will break a dyno intermediate shaft and twist splines and all kinds of nasty stuff, Everyone of these type tractors I have ever lightened the flywheel in has worked an pulled better. Thats fact. I have noticed no loss on the dyno. I have noticed a big difference in how they react when your driving and taking off. Thats a factor the dyno can't give you. Point being, Take you head out of the sand,Read everything you can get your hands on if you don't understand ask a question don't try to reinvent physics!
ChadS
02-14-2007 16:59:58
 Re: The 200 hp M theory,,, in reply to LW, 02-14-2007 16:33:09
Thanks LW. Ok, onthe rpm rasing hp theroy,,, look at an IH 6cyl gas engine. Sorry, its red, but it will prove my point.
Ih 460 with a 221 is what,, 50 hp at 540? what is that,,, 1900 rpm?
Take that same exact motor, throw it into a truck and rev it up to 3600. Which is exactly what IH did, used the same engine in trucks and tractors,, and got 137 hp at 3600 rpms. Out of the same 221ci engine.
Tell me again how that theory dont work???
if it can be fed it will make power.
I belive you on how you tune it with an O2 sensor,, shoot it takes all the fun out of pulling all the plugs out to check em for color!LOL!! Do you measure exhaust temp as well?
The heavy flywheel is meant for a stock engine setup,,, I never said the lite ones dont work on modifieds,, they work better when your lugging the crap out of a stock engine. its more meant for lower than low rpms to keep momentum going. If it was meant to give momentum, running a baler, or run the hyd pump,,, why wouldnt the same theroy work on a pulling track? if an engine, is to its point of dying,, and a few extra pounds of momentum keeps it going for a few more seconds,, that can be the difference between 1st or second place when its lugged down to its knees. Now balance of the flywheel would smooth it out, add weight and balance it would be even better in my opinion. Seen a G JD once, put 2 flywheels welded together,,,,, he idled that thing down, and made the most hook em up beat your pants off, take your money pull you have ever seen. And all it did was keep the engine running at a lower rpm from the extra momentum. I thought it would die, but the flywheel would go around and go again. Never seen anything like it. He used the low end torque created from momentum,, I guess you called it free,, cause the engine did not do the job, it had a helper,,,,, maybe it dont make sence,,, but Ive seen it in action. Is momentum considered torque?? when thats what momentum is creating? Chad
LW
02-14-2007 17:09:05
 Re: The 200 hp M theory,,, in reply to ChadS, 02-14-2007 16:59:58
THat still blows holes in your theory Your math won't even work there, the math you showed you used the other day will not come up to 137 hp, at the rpm. Look there are lots of engines that will make more power at more rpm. That particular engine had a differnet carb, intake alot of things were different in the trucks. Tractors were engineered for peak torque of the engine to be in their specified rpm not the engines peak Hp.A engine could well have made peak torque @ 900 rpm and peak Hp @ 1600, these are just #'s. The engine could have been put in a tractor with a max. rpm of 1500.
ChadS
02-14-2007 17:22:10
 Re: The 200 hp M theory,,, in reply to LW, 02-14-2007 17:09:05
Right, but the HP numbers were not for a 460,, they were for my engine,, Ih 6 cyl, but not a 221. just an example,,, Sure they had different induction setups,,, different timing settings etc etc,,, but thats the same thing id have to do to make that engine run high rpms,, right?? Bigger carb, change the timing, etc etc. thats what they do when you turn up the rpms. You wouldnt run the big rpm parts on a low rpm engine would ya??? on the 221 hp,,,
id say its 50 hp,,, a 460 is,,, at 1900 rpm,,, would be 94 hp,, but, consider the changes you mentioned to run the higher rpms,, add the parts and probably pick up a bunch of power. I took my 263 hp at 1815,, 78hp at 3600 is 154 hp. I can belive its possible to be that strong at that rpm. Very possible. The book I got on the 137 hp is from a motors manual I have from the late 60's,, covered all of em,,, Please leave room for clerical error on my part,,, LOL, Im full of it we all know,, it may have been a 263 I seen, not a 221, so I gotta doctor the numbers,, just a tad,, LOL! But really,,, it works,, sure, you have to tune em, do what you have to do,,, we know that that area has to bigger to run the high rpms. tractor carbs/ intakes probably die off at 3200,,,,, Chad
Real Puller
02-15-2007 08:11:33
 Re: The 200 hp M theory,,, in reply to ChadS, 02-14-2007 17:22:10
Computer: $899.99
Monthly internet service: $19.98
Laughing at chad’s laws of physics: Priceless
john henryson
02-12-2007 14:25:15
What did you just say?? Kids the lesson here is just say no to drugs and dont marry your sister!!!
Real Puller
02-15-2007 08:22:00
 Re: The 200 hp M theory,,, in reply to john henryson, 02-12-2007 14:25:15
....and stay in school.
