MSD on WD ALLIS
C.D.E. Puller
02-14-2007 07:49:23
I put msd on my wd I was woundering if it changed the way I need to run my timing ? I also have a different cam and 1.85 rockers.
C.D.E. Puller
02-16-2007 07:16:47
 Re: MSD on WD ALLIS in reply to C.D.E. Puller, 02-14-2007 07:49:23
How is the best way to get the degrees on a wd it only has the two marks on the fly wheel and center on the bell housing ?
Cody
02-16-2007 07:21:24
 Re: MSD on WD ALLIS in reply to C.D.E. Puller, 02-16-2007 07:16:47
Pull the head off and put you a dial indicator on top of the #1 piston. find TDC and make you a mark on the front pulley that is easily visable. Then use a timming light that has the adjustable advancement built into it. Dial it up to 20deg. adv. and line up the marks.
Cody
02-15-2007 12:47:30
Assuming you are running in the 2000 rpm range, put the timming on 18-21 deg. should be very close.
