Tractor weight
Andy
05-02-2002 17:38:23
I have a Super M I have pulled a little, in 6500 lb. I have 16-9-38's on it, full of water, when I pull I spin out, trottled way back, then starts jumping, just woundering if I should weight it and go in7500,and 8000lb what are the experts thoughts thanks
Puller504
05-14-2002 03:50:39
 Re: Tractor weight in reply to Andy, 05-02-2002 17:38:23
Hi Andy. You are bouncing with water in your tires because water does not compress. If you remove the water, and set the air pressure in the tires around 1 psi per each 1,000# of class you pull, Example: 5 psi in a 5000# class, the tires should flatten their profile on the track and will probably not bounce. (in my experience).
buckmaster700
05-06-2002 17:41:07
get rid of the water hang on cast and set your draw bar as high as your aloud . the fluid will in time trash your gears
