farmall 460, 8000 lbs
bm3501466
02-28-2007 14:52:02
Is it safe to load a 460 up to 8000 lbs? I would be pulling probably up to 20,000 lbs dead weight. I have plenty of power. Will the rear end hold up without jerk starts? I plan on putting as many wheel weights as possible to reduce harm on the tractor, but there is only so much I can put on the wheels. Is this ok or just plain stupid?
mshultz
02-28-2007 18:44:32
 Re: farmall 460, 8000 lbs in reply to bm3501466, 02-28-2007 14:52:02
there"s a couple 460"s that start around 8,000 here and pull up around 11,000. Us and another guy pulled our Ms up to 14,000 at one pull, and we pull our H up to 7500 pretty regular. Wouldn"t think you"d have much trouble, but we oinly pul transfer sled - don"t know how dead sled would be.
MJF
03-01-2007 13:38:29
 Re: farmall 460, 8000 lbs in reply to mshultz, 02-28-2007 18:44:32
Thats a good H you guys have, was it 6000 or 7000 that you guys pulled it in last year at Beaver Springs and won. Even beat the M you guys had there. There was a pile of strong tractors in that class.
mshultz
03-02-2007 18:19:40
 Re: farmall 460, 8000 lbs in reply to MJF, 03-01-2007 13:38:29
7000 class we won out there. It really likes getting heavy - I think it would be competive in 8500 pace at west end and beaver, but not sure we want to test things that hard :)
We might pull 4500, 5000, and 6000 with it at MAFMCA this year - can't run against the M's in the non-pace classes over 5000, but can get them in the pace.
At west end we ended up 3rd in te 14000 with the M this year - shively won it with his M. Not sure if we'll do it again or not, but I'm guessing dad will want to.
460anger
02-28-2007 15:25:43
I pull my 460 from 5500 to 9000 had proplems with the main cluth after putting in a 6 button clutch and heavy duty pressure plate have had no more proplems. Glad to hear from someone pulling dead wieght thats the only pulling I do. Anybody can pull transfer sled and do good.
Andrew Z
02-28-2007 15:47:36
 Re: farmall 460, 8000 lbs in reply to 460anger, 02-28-2007 15:25:43
Last summer I saw a 460D pull in the 7500lbs class If I recall it got 6th oth of 20 tractors pretty dam good. A SMTD won the class tho. it was a fun class to watch.
Andrew
