pertronix ignition
52 G
03-10-2007 19:41:34
Is it possible for the electronic ignition to missfire on one cylinder on a JD G, or when they go, do they just go all together.The left cylinder quits at higher rpms, and pops and blows yellow flames, but the right side never misses at all. Does'nt seem like gas problem due to the fact that the left cylinder usually gets most of the gas to start with. The fire looks the same on both sides at cranking speed, but could this change at running speed due to a bad ignition. any help is appreciated.
keddano
03-13-2007 22:02:05
 Re: pertronix ignition in reply to 52 G, 03-10-2007 19:41:34
2 ways to try and check,First and best..Find someone with a old Sun Scope (Ocillascope) (spelled wrong),If you could put it on a dyno at the same time you'll see everything. Or you might be able to use a clamp on timing light on that cylinder and see if you lose the stobing at high rpms. just a couple of options
B-maniac
03-14-2007 14:35:42
 Re: pertronix ignition in reply to keddano, 03-13-2007 22:02:05
Put the points back in and if that solves the problem then leave them in it. We sometimes tend to "over think" these ole tractors.
