Whats the higest gear you can pull in.
bigbadM
03-17-2007 18:48:25
In an open class whats the higest gear you can pull in on a farily stock M while still geting a good distance.
560 Farmall Puller
03-18-2007 19:33:09
 Re: Whats the higest gear you can pull in. in reply to bigbadM, 03-17-2007 18:48:25
When we first got in to pulling we started with a Super M it had about 70 H.P. which we thought was really good, we found out different. I was in an open class got about half way down the track and it died in 2nd gear. The next class, I was still in a Div. 3 class without cut tires and backed down to first and finished a lot better. Still out classed by the cut tire tractors but finished in the middle of the pack.
pullr
03-18-2007 16:16:28
Since everyone is having fun, how bout nuetral? Seriously with a Stock M Farmall probably 1 gear,2nd at the most.
jd lover
03-18-2007 08:27:40
reverse
Buzzman72
03-18-2007 09:50:04
 Re: Whats the higest gear you can pull in. in reply to jd lover, 03-18-2007 08:27:40
Obviously, you're talking about your JD M.
Dan 560
03-18-2007 08:25:25
5th
Dairy Farmer in WI
03-18-2007 19:03:06
 Re: Whats the higest gear you can pull in. in reply to Dan 560, 03-18-2007 08:25:25
ARE YOU CRAZY!?! you wouldn't even move an inch with a stock M. you'd kill the tractor before you'd even budge.
Agco Avenger
03-18-2007 06:12:36
1st.
pllr
03-17-2007 19:01:12
2nd
Ol Gray A
03-18-2007 06:43:12
 Re: Whats the higest gear you can pull in. in reply to pllr, 03-17-2007 19:01:12
3rd
Happy 350
03-18-2007 08:24:09
 Re: Whats the higest gear you can pull in. in reply to Ol Gray A, 03-18-2007 06:43:12
4th
buickanddeere
03-19-2007 06:44:36
 Re: Whats the higest gear you can pull in. in reply to Happy 350 , 03-18-2007 08:24:09
5th
dad's88
03-22-2007 02:01:43
 Re: Whats the higest gear you can pull in. in reply to buickanddeere, 03-19-2007 06:44:36
HEY! YA didn't leave none for me guys!
nine speed
03-22-2007 06:44:46
 Re: Whats the higest gear you can pull in. in reply to dad's88, 03-22-2007 02:01:43
Wasn't there a 9 speed available for that model?
