after market air filter on john deere
ajdeereman
03-20-2007 19:29:41
Will I gain anything by getting rid of the oil bath air cleaner and putting on a aftermarket one on. If so what would work good. And if so will I have to readjust the carb.
2 Cylinder
03-21-2007 07:44:39
 Re: after market air filter on john deere in reply to ajdeereman, 03-20-2007 19:29:41
You will gain better air flow if nothing else. Auto Zone carries a K & N look alike cone air filter for about $16-20 that I run on my JD-G using the stock intake pipe turned 180 degrees. May be able to give carb a little extra fuel, but I would let a dyno determine the need for that.
2 Cylinder
03-21-2007 07:44:33
