how many CFM's needed
ajdeereman
03-22-2007 18:16:41
How many CFM's are needed when putting a paper filter on a John Deere 60
dboll
03-23-2007 04:59:37
 Re: how many CFM's needed in reply to ajdeereman, 03-22-2007 18:16:41
the guys at the K&N tech line can tell you if you provide all pertinent information
Crutch
03-22-2007 19:23:44
Try this,
(CID\1728) X (Half-max-RPMs X .65)
Example 400 cid at 1200 rpms with .65 Vol Eff= @ 90 cfm 1728 is a constant, use half peak rpms, .65 is volumetric effeciency.
If I wrote this right it would guestimate the CFM requirements for a carb which would be the same as the filter or just use a filter that will flow more than the carb.
