Loosing Weight...!!
BushogPapa
04-09-2007 21:36:27
I Finally found a way to get my tractor 320 Lbs Lighter..!!
8 Quarts of 10 weight is 320 Lbs Lighter than 8 Qts of 50 weight...!!!
40x 8=320..!!!
Now, I can get into that next Class..!!!
Mike n Mo
04-10-2007 04:50:28
 Re: Loosing Weight...!! in reply to BushogPapa, 04-09-2007 21:36:27
Another easy way to lose a little weight is to drop your air pressure. If you go from 15 lbs down to 10 lbs in the rears, and from 30 to 20 in the fronts, thats a total of 30 lbs for all 4 tires!!! Mike
Drew
04-10-2007 10:05:53
 Re: Loosing Weight...!! in reply to Mike n Mo, 04-10-2007 04:50:28
How much weight would I lose if I put 15psi of helium in the tires instead of air?
MJF
04-11-2007 18:49:52
 Re: Loosing Weight...!! in reply to Drew, 04-10-2007 10:05:53
I dunno about the tire weight, but the flotation of helium in the tires would be awesome :)
Steve Van Drimmelen
04-10-2007 12:42:03
Let's see, 18.4 x 38s, 20" wide like you have...hmmm. I'm thinking 5 lbs a tire but that's only if you run WFO.
Drew
04-10-2007 15:18:12
 Re: Loosing Weight...!! in reply to Steve Van Drimmelen, 04-10-2007 12:42:03
If you run WFO, then you need a spoiler to put more downforce on the rear tires. But dont put any stickers on the spoiler, LMAO!!!! :-)
Steve Wiiest
04-10-2007 04:44:15
Is that gear oil??
willywonka2
04-11-2007 15:16:44
 Re: Loosing Weight...!! in reply to Steve Wiiest, 04-10-2007 04:44:15
I think that whole thread was loaded with sarcasim Steve
