Gear reduction starter
Andrew
05-09-2002 18:07:55
Does anybody make a gear reduction starter for a JD "B"? If so, about how much do they cost, and where could I get one?
G Taylor
05-11-2002 21:14:40
 Re: gear reduction starter in reply to Andrew, 05-09-2002 18:07:55
A high CCA 12V (800+ amp) battery connected to the stock 6V starter will crank most pulling tractor engines. Use large cables with soldered connections & connect the ground right to the starter case.
Jerry @ Pullsite
05-11-2002 19:12:22
I'm Andrew's old man...He went up north for the weekend and can't respond to these posts. Instead of counting sheep at night, it's souped up JD B's instead...Man, I hope the money don't run out...Anyway, it's a '41 B with a 6-spd. tranny. By the looks of things, we both might be better off drinking muscle shakes and hitting the weight bench - doesn't look like there's a dime store way of getting around the starter issue.
WTW
05-10-2002 12:56:37
Andrew, As G-man asked if your starter is located on top of the case and not the bottom I can help you as I have been through this myself. The gear reduction starters that most people are using for A's and G's will not work on your B because the location of the solenoid will interfere with the steering support post on the B. The starter that will work is off a B series Cummins diesel and has the solenoid in the right location that will allow it to bolt right on your B with out interference, that is if your starter is on TOP. If you go to a Cummins dealer for this starter they will want over 600.00 for a new one and around 350.00 for a rebuilt one plus core charges if you do not have a core. I found a supplier that I got two (new) not rebuilt ones for the last two B's that I built for around 250.00 a piece but that was about three years ago, probably higher now. I would give you a Delco part number but I do not have access to it right now. I can get it if you need it. Let me know. They are Delco gear reduction starters. Good Luck Dave W.
David H. Ransom
05-11-2002 13:34:04
 Re: Re: gear reduction starter in reply to WTW, 05-10-2002 12:56:37
The last two B's YOU BUILT?
Justin
05-10-2002 14:49:56
WTW, do you know what are the starters most are using are off of? I have one on my G but no one I've ever talked to has a sure answer. Most think it's off of a Power Stroke.
Justin
Gman
05-10-2002 16:09:34
 Re: Re: Re: gear reduction starter in reply to Justin, 05-10-2002 14:49:56
Justin I have purchased a Iska (solinoid burned out) and I purchased a Nippondenso starter.I just ask for a starter for a 4000 or 4020 John Deere. The Nippo I had to modidy crank case cover a little. These will fit "G"'s or any three bolt John Deere mounting bracket if you got the room they aren't gear reduction. Garland
Justin
05-10-2002 16:13:41
 Re: Re: Re: Re: gear reduction starter in reply to Gman, 05-10-2002 16:09:34
The one I have is a gear reduction. The only modification I had to do was to the shround around the flywheel. Where the starter bolts to the bracket, it's thicker. That caused it to pull the shround back a little bit and it was rubbing the flywheel. I took a die grinder and ground the holes out a little bigger where the shroud bolts up and haven't had anymore problems. Those starters sure make a big difference.
Justin
Gman
05-10-2002 16:08:39
G-MAN
05-10-2002 10:51:43
Depending on what year your B is, a gear-reduction starter off of a later JD 8000 might fit it. If your starter is on top of the main case, I'm pretty sure it will - although not %100. It will fit on my G, at least, and the bolt pattern should be the same. Those starters are pretty high-dollar, though - probably in the $500 range for a new one. Maybe you can find one at a salvage yard. Just my two cents.
