new powerblocks
bm3501466
04-23-2007 19:53:13
How much are these new powerblocks that Murphys is making? I want one for a 39 B.
fxstc87evo
04-24-2007 15:29:44
 Re: new powerblocks in reply to bm3501466, 04-23-2007 19:53:13
If someone is making blocks, they must be making pistons. Any help in that department?
jd b puller
04-24-2007 16:45:07
 Re: new powerblocks in reply to fxstc87evo, 04-24-2007 15:29:44
I can help with that as well. Call me at (919)341-8685 or e-mail and I'll call you.
Mopar-Harris
04-25-2007 13:29:53
 Re: new powerblocks in reply to jd b puller, 04-24-2007 16:45:07
Just out of curiousity, how big are the B blocks getting?
jd b puller
04-25-2007 20:11:21
 Re: new powerblocks in reply to Mopar-Harris, 04-25-2007 13:29:53
5.75" and 6.125"
GPULLER
04-26-2007 08:07:46
 Re: new powerblocks in reply to jd b puller, 04-25-2007 20:11:21
How much stroke can be stuffed in one?
jd b puller
04-26-2007 17:36:25
 Re: new powerblocks in reply to GPULLER, 04-26-2007 08:07:46
Not sure i understand your question. As much as you can fit. Depends on your pistons, how far you shove the pistons into the block, how much work you want to do in the crankcase, (crank has to clear the camshaft, top of the case, oil pressure head, back of the crankcase, etc). Not sure how the block would be your limiting factor on stroke.
On a B, it's pretty easy to get 7"
at 7.5" you get pretty rough on the back of the case
at 7.75, it gets rough on the cam, the top of the case, and the back of the case.
Above 8 it gets real hard
And much above that you have to get creative.
Drew
04-24-2007 16:44:27
Murphy's can make pretty much any size piston you need.
JDGnut
04-23-2007 20:36:53
I don't think he's making them for a B's.. at least not yet... but there's a few rumors of someone else casting the B blocks...
JDGnut
jd b puller
04-23-2007 20:47:53
 Re: new powerblocks in reply to JDGnut, 04-23-2007 20:36:53
Aye, the rumors be true. Both of them. - Murphy"s doesn"t make them. - Someone else is.
I"ll send you an e-mail.
Gary from Muleshoe
04-24-2007 06:29:24
 Re: new powerblocks in reply to jd b puller, 04-23-2007 20:47:53
Would you send me info on the JD B power block also? Email open.
