stroke crank in 39 b johndeere
720billy
04-28-2007 17:23:26
im putting a 2 inch stroke in my b its hiting the oil canister in center of tractor can you give me some help thanks billy
deereman_39
05-03-2007 15:43:25
 Re: stroke crank in 39 b johndeere in reply to 720billy, 04-28-2007 17:23:26
have a 39 B with a stroker in it, oil pump body has to be ground and clearanced to make fit. mine has a 7 1/4 stroke with farmall h rods
jugs
04-29-2007 20:05:05
use an assembly from an H
jd b puller
04-29-2007 15:46:10
How bad is it hitting? Who did your crank, did they move the journals outward at all? Do you have the endplay set seasonably close? Is it hitting both cylinders or just one? Which one? I don't remember it being that close.
720billy
04-29-2007 19:35:03
 Re: stroke crank in 39 b johndeere in reply to jd b puller, 04-29-2007 15:46:10
jd b puller need your phone # would like to talk to you thanks billy
jd b puller
05-01-2007 04:06:19
 Re: stroke crank in 39 b johndeere in reply to 720billy, 04-29-2007 19:35:03
E-mail is open. Phone is (919) 605-6040.
joepull
04-28-2007 20:00:12
cut the divider wall out. Wash transmission out good, run all motor oil.
720billy
04-29-2007 07:22:43
 Re: stroke crank in 39 b johndeere in reply to joepull, 04-28-2007 20:00:12
not the back wall the oil canister thanks billy
