how to switch a john deere 60 to negative ground
ajdeereman
05-06-2007 19:32:14
What all needs to be done to switch a john deere 60 to a negative ground electrical system.
phil2
05-08-2007 15:18:43
 Re: how to switch a john deere 60 to negative grou in reply to ajdeereman, 05-06-2007 19:32:14
?? why do you want neg ground?
ajdeereman
05-07-2007 11:24:06
do I have to do anything with the starter
Dave in Tx
05-07-2007 06:35:06
Switch the batt cables, switch the wires on the coil, polarize the generator....Can't think of anything else.
Mike Aylward
05-07-2007 06:42:12
 Re: how to switch a john deere 60 to negative grou in reply to Dave in Tx, 05-07-2007 06:35:06
You will also want to switch the wires on the ammeter. Otherwise it will show discharge when it is charging. Hope this helps. Mike
