Michigan Shootout Jackpot Pull
CAFPC
05-15-2007 11:32:52
third party image
Bring your best pulling tractor for a chance at $200! Plenty of shade for watching too. We'd love to see ya.
LRN
05-17-2007 11:10:37
 Re: Michigan Shootout Jackpot Pull in reply to CAFPC, 05-15-2007 11:32:52
I'm sure that we will let someone pull if they are running a 20" drawbar. There are a lot of tractors running with turnbuckles that can be quickly adjusted. Let's put it this way, you can run what you have18", 19" or not over 20". This is just going to be a fun thing anyway. Hope to see you there.
LRN, Sec/Treas. CAFPC
Single Front Wheel
05-17-2007 19:55:13
 Re: Michigan Shootout Jackpot Pull in reply to LRN, 05-17-2007 11:10:37
Lets put it this way, I didnt place that advertisement up here, BUT, let me clarify, the rule is 19". Everybody"s Anybody has a drawbar that is adjustable. It will be at 19". EVERYONE WILL BE THE SAME. Believe me, I"ll be checking at the scale. Andrew Curry andrewcurry21@msn.com 1 269 921 4686
LRN
05-18-2007 09:47:47
 Re: Michigan Shootout Jackpot Pull in reply to Single Front Wheel, 05-17-2007 19:55:13
I guess I stand corrected, LRN
Gary Baker
05-16-2007 17:56:56
In your add you say Div 3-4 NATPA tractors are legal. Then you say 19" hitch height. NATPA Div 3-4 tractors are 20" hitch height. You need to allow 20" hitch height if you want to bring in tractors for your pull. Gary
Mopower
05-18-2007 13:07:46
 Re: Michigan Shootout Jackpot Pull in reply to Gary Baker, 05-16-2007 17:56:56
Hi Gary. Our club uses 19" across the board because it is between most Michigan clubs regulation of 18-20". We kept this hitch height for the shootout for enforcement simplicity and also making the stakes a tad different. That is why the weight classes are #3800 and #5800. Just a bit different. LRN is correct. If you wanna pull 20", you can hook as many times as you like, but you won't qualify for the jackpot. No, it doesn't match NATPA, that's why I thought I'd better mention it in the ad. Most NATPA machines can adjust an inch. My hitch moves 1/2" either way depending on the sun and temp. I hope to see ya there Mr. Baker!!!
