Leslie Tractor Club is having their first pull of the 2007 season at their home track, 4409 E. Race Rd. They have new classes and new rules for this year. 1. Antique: 59 and older. Max tire size 0-6500lb 229 sq in. 6501-10000 300 sq in. top cuts only, 3mph, 3 beeps on horn, weights 11 ft. forward of rear axle and not behind radius of rear tire. Stock RPM 10% margin. Hitches 18" back, 18" high. Wheelie bars per NATPA chart, W/O wheelie bars hitch must be behind radius of rear tire. Weight classes 0-2750, 3000lbs. and then every 500lbs up to 6500. then 7500, 8500, and 10000lbs. 2. Antique plus: 59 and older. Tires 18.4X38 any cut. Speed 4.5 mph. Front weights 11 ft. from rear axle. RPM 20% margin. Naturally aspirated. Wheelie bars and kill switches. Hitch, 18" back 20" high Weight classes 0-3500 and every 1000lbs up to 8500 3. Farm stock: Tires 24.5X38 noncut. 5MPH. Hitch 18" high behind radius of rear tire. RPM 10% margin. Engine, frame, turbo and pump to be as came from factory. They also run a complete line of garden tractor pulls from stock to VW and snowmobile powered units. Pulls start around 10AM
