PARK RAPIDS TRACTOR PULL
Buda Power
05-27-2007 06:19:54
Park Rapids Antique tractor and engine club is holding three pulls this year, June 9th, Aug 4th, and Sept 29th. Weigh in will start at 9, and pull at 11.
1st-3rd place, 70% cash payback Stock classes will be 3000,35,45,5000,55,6000,65,75,85,95 @ 4mph
Hot Farm 3500, 5500,& 7500# @ 8mph From Hwy 71 & 34, east on 34 to cty 6 & south 1/2 mile For more info call: Mike @ 218 732 5119 or 5406 Steve @ 218 252 4479, or 732 4479 Tim @ 218 252 0555
Josh Wilhelm
05-27-2007 07:27:18
 Re: PARK RAPIDS TRACTOR PULL in reply to Buda Power, 05-27-2007 06:19:54
Hi there how many times can a guy pull a tractor? Can we pull both stock and hot farm with the same tractor? How is your track? Thanks alot...
Buda Power
05-27-2007 15:15:58
 Re: PARK RAPIDS TRACTOR PULL in reply to Josh Wilhelm, 05-27-2007 07:27:18
Josh, the guys just worked the track last weekend, picked stones again and packed it back up in layers, should be a good power track again. We were limiting it to three hooks per tractor. If it will make a stock class you shure can pull in hot. What color were you planning on brining?
Josh Wilhelm
05-27-2007 18:01:46
 Re: PARK RAPIDS TRACTOR PULL in reply to Buda Power, 05-27-2007 15:15:58
Most likely green and red. You must be a Cockshutt guy? I was looking at my scheduel what skid are you using. The Kandiland skid looks buissy those days. Most stock stuff around this area is pritty forgiving on rules. What are the major guidelines. Are you alowing cut rubber in the hot classes?
