roosamaster pump
4010 deere pul
05-29-2007 10:05:06
I nead info on how to turn up the pump on my 63 4010 please help pull coming up on sunday. nead more power. thanks
brianIH
05-29-2007 18:23:51
 Re: roosamaster pump in reply to 4010 deere puller , 05-29-2007 10:05:06
The fastest way to get a little more out of your pump is to loosen the torque screw.The srcrew to turn up the fuel is inside the pump.Best to get someone that has done it before or a diesel shop.Where are you from?
4010deerepuller
06-04-2007 14:17:07
 Re: roosamaster pump in reply to brianIH, 05-29-2007 18:23:51
Iam from New Jersey it is hard to find any one to work on theese localy so I learn by tryal and error. is the screw the one inside that you have to line up in the hole by rotating the engine. If im not mistaken it should be an allen head. how far should I back it off? thanks for your help
