Oliver 88 brakes grab
BlakeG
06-07-2007 18:51:35
any ideas of what i can do, or need to do to keep my brakes from being so grabby, becuase as it is right now, i can't use them while pulling becuase they grab and wont relaese until im to a stop. Thanks
Benner
06-10-2007 14:37:36
 Re: Oliver 88 brakes grab in reply to BlakeG, 06-07-2007 18:51:35
You need to take the brakes apart and clean up the casting where the accuators ride, youll notice a groove worn into the housing and also take the accuators apart and clean up the holes where the balls ride with a piece of sandpaper, if there is oil on the pads replace the seals in the housings, and then spray the disks with brake cleaner and heat them very lightly (after the brake cleaner is gone) to burn the oil out. and you may want to check your hydraulic level it is common on them to have a leaking hydraulic unit and over fill the rearend
D-Day
06-07-2007 20:18:41
They probably have some oil on them. Take the discs out and clean them off with brake cleaner or WD-40 to make sure they're clean. That should help.
