Hey Jimmy!
ChadS
06-12-2007 06:36:54
Ever see one catch fire, while trying to "burn" one out? Bout burned a 3010 JD to the ground the other day following the burn out method. Caught the oil on fire that had splattered out the exhaust pipe from all the exxcessive heat it takes to burn all the trash. Most of us have to WORK on em and still use em while we PLAY! Im just along for the ride. Something to think about there, and this is a young fella telling an elder,, "When you point a finger, you have 3 still pointing back at ya" so keep that in mind when you talk about others. On the money issue,,, put your money where your mouth is, cause the only way I want your money is to take it from you on the track. We got a BIG pull comming up in July, and you can do your best in front of a crowd of 30,000+ Hook up to a real sled. Talk to you soon. Chad
