wheelie bars
slowrideII
06-12-2007 07:04:33
third party image
i welded these up the other day and painted em today. what do you guys think? the welds are a little sloppy, but the paint covers it up a little. the tractor is a john deere 50. these are my first set of homemade wheelie bars.
slowrideII
06-14-2007 06:46:11
 Re: wheelie bars in reply to slowrideII, 06-12-2007 07:04:33
thanks for the tips, guys! i guess i'll test em out this weekend at the clinton, wisconsin pull. wish me luck!
slowride>
turbos10
06-13-2007 18:27:39
Around here just about anything goes....which is not always safe, but seems to be the way it is.
I see a few things that I would do differently next time; the top bar is connected via a peice of strap and a bolt, and the bottom bar is tied to the braw bar. Ideally, you want the draw bar and wheelie bars separate in case one fails the other will not(hopefully). The problem with the strap is that it will bend much more easily than the tubing. So, if you came up at an angle for some reason you could potentially bend the bar. As mentioned before, tying them together would also help with strength.
However, if you have tested them with a jack one at a time, they should probably be safe.
Chris
clinton
06-13-2007 12:42:21
It looks as if you have them bolted to the drawbar frame. Most clubs will not allow that.
Mike Aylward
06-13-2007 10:40:45
Slow, for the most part they look ok. But I am bothered by the top member of the bars. This should not have the joint and bolt in them. This area could possibly fold on you as it appears to be a stress point. The upper member should be tied together or be one piece, in my estimation. They may work fine the way they are, but this two-pieced feature scares me. Mike
JRB- Ind.
06-12-2007 20:31:17
Looks good, but, your pads should be a little bigger. The reason is to keep them from digging in on a soft track. Easy fix though. Remember, its your life that might be saved. Be safe.
Farmall H Puller
06-12-2007 08:51:25
Looks like a real nice set of wheelie bars.
champspa
06-12-2007 07:14:16
jack them up by the wheelie bars with as much weight as your pulling on the tractor and see .Looks like a life saver to me .
slowrideII
06-12-2007 08:50:20
 Re: wheelie bars in reply to champspa, 06-12-2007 07:14:16
yeah i jacked em up a few times. they groaned a little the first time, but i did it a few times more and they worked just fine.
