John Deere G
Albert P
06-22-2007 19:57:21
I need to know how far you can stroke a G and not go through the back wall? Thank you for your time!
Life of riley
06-22-2007 21:49:38
 Re: John Deere G in reply to Albert P, 06-22-2007 19:57:21
8.75 inches if you use JD A rods. You'll have to do a lot of grinding up top though.
JDGnut
06-24-2007 21:45:28
 Re: John Deere G in reply to Life of riley, 06-22-2007 21:49:38
Yea at 8.75.. its going to be paper thin at the top.. or you'll can trim the rods down a little.. and the cam will need some serious grinding.. trim off the end of the rod cap studs or replace them with bolts.. and polish up the back of the case in a few places.. I'd just cut the windows in.. it much easier with the 4020 rods...
Life of riley
06-25-2007 17:35:18
 Re: John Deere G in reply to JDGnut, 06-24-2007 21:45:28
Yeah easiest to just cut the top totally out and cut some tin and lay over the holes. I agree w/ JDGnut it may be easier just to use the 4020 rods. You'll have to cut the back of the case out but they will clear up top.
