Is using 110 race fuel breaking the rules?
110 race fuel
06-28-2007 20:15:26
Im wondering if i use 110 race fuel if its breaking the rules, and if it is, what are the chances the rules will be enforced?
Yes most places
06-30-2007 00:23:29
 Re: Is using 110 race fuel breaking the rules? in reply to 110 race fuel, 06-28-2007 20:15:26
110 is legal under most rules,it is below the specfic weight that NATPA enforces.
AW Puller
06-30-2007 07:05:35
 Re: Is using 110 race fuel breaking the rules? in reply to Yes most places, 06-30-2007 00:23:29
Below the specific gravity that NATPA enforces..... or do you mean under the specific gravity that NATPA has listed in the rules?
I could be wrong, but the way I understood it at the NATPA meeting a few months ago is that they have no way to enforce the rule on specific gravity of fuel.
HossW
06-29-2007 20:34:02
Rules are for suckers!
110 race
06-29-2007 16:55:39
I'm at 9.8 to 1 and my cylinder pressure is 270psi what is yours at 11 to 1. another farmall puller
buickanddeere
06-30-2007 08:52:51
 Re: Is using 110 race fuel breaking the rules? in reply to 110 race, 06-29-2007 16:55:39
Must be a short duration cam in there?
Jak
06-29-2007 07:48:30
Around my area no one gives a crap what you burn.Heck once a guy was burning laquer paint thinner,boy that smelled wierd.Now if it was hitting a mean lick/choppy idle and smelled of nitro methane in farm stock someone would say something.
buickanddeere
06-29-2007 07:29:26
Odds are using E-85 with larger carb jets will make more power even on a stock engine. Adding octane to an engine that already has enough octane to prevent detonation, gains ZERO.
Trkr
06-29-2007 05:30:34
What compression ratio are you running that requires 110?
110 race fuel
06-29-2007 12:44:18
 Re: Is using 110 race fuel breaking the rules? in reply to Trkr, 06-29-2007 05:30:34
im some where in the range between 10.5-11 to 1 compression, and some guys say im missing some easy power gains becuase im not using 110, ive tried mixing ethonal in, and tried preimium gas and premium with booster added, but am curious if i have alot to gain with the risk of running 110 and getting caught, plus the price of it is alot to chew! thanks
puller23
06-29-2007 13:47:49
 Re: Is using 110 race fuel breaking the rules? in reply to 110 race fuel, 06-29-2007 12:44:18
Octane doesn't make power. Octane lets you raise compression, increase timing, and have a poorer cylinder head design. If it doesn't knock on what you have, save your money.
110 racing fuel
06-29-2007 04:57:15
Is there any fuel booster that works just as good but harder to detect? becuase i know what your saying about the smell, you can tell whos running race and/or avgas. Or can i buy the additive that makes it smell like cherrys or cotton candy? does that work or just draw more attention?
Eddie Haskell
06-29-2007 03:40:39
It ain't breaking the rules unless you get caught.
ShaggyM
06-28-2007 21:34:16
There was something on here a week or so ago about the same thing. Most rules say pump gas and I know I can get 110 at several gas stations around here. Shaggy
MN Dave
06-28-2007 20:56:12
Most pulls around here are quite specific about use. It's pretty easy to tell if someone is using it, the exhaust has quite a specific smell to it. Also, the racing gas I use in my open tractor is blue.
