Intake manifold gets frosty!?
BlakeG
07-02-2007 17:05:23
on my oliver 88, i have a 880 intake and a carb off a jd 6600 combine that i have drilled out, seems to be running ok, but the intake manifold gets cold and frosty after running at idle, high and low, right above the carb what causes this, and should it be corrected, if so how? thanks for any input!
Farmall MD
07-04-2007 11:37:03
 Re: Intake manifold gets frosty!? in reply to BlakeG, 07-02-2007 17:05:23
Blake, I was always told that is a good sign. Means you got great flow thru everything. Also, you want a manifold that gets as cold as you can get it. The colder the air intake the more air/fuel gets packed in the cylinders. Doug N
BlakeG
07-04-2007 20:35:22
 Re: Intake manifold gets frosty!? in reply to Farmall MD, 07-04-2007 11:37:03
Thanks for the reply, sounds good to me, ill just leave everything the way i got it then!
