Hey oliver guys
BlakeG
07-08-2007 07:12:46
What size and brand of tire works best for you on your olivers, i have a 88 and just cant get the power to the ground, any help would be great...as im tired of spinning out before everyone else, ive tried diffent pressures and moved wieghts around and still no success!
KEDDANO
07-09-2007 13:47:06
 Re: Hey oliver guys in reply to BlakeG, 07-08-2007 07:12:46
I RUN 15.5'S ON MINE,HAD GREAT LUCK WITH 45 DEGREE bars,about 3/4" tall,for the last few years.Just changed to a set of Firestone 15.5's 23 degree,verdict still out after 2 pulls,but doing good.One thing some people overlook,A bigger tire has least pounds per square inch to the ground then a narrower tire.
Oliver?
07-09-2007 07:00:25
Is the safemark tire a Multi-Angle which is a long bar short bar tire not to good for pulling if so you my need to find a long bar long bar tire .
KT4387
07-08-2007 13:51:42
NOT KNOWING YOUR SET-UP I SAY THIS. POWER TO THE GROUND STARTS WITH WEIGHT, AND HOW IT IS PLACED. HITCH LENGHT? HITCH HEIGHT? IF YOUR NOT PICKING UP THE FRONT, YOUR NOT HEAVY ENOUGH ON THE HITCH. TIRES ARE YOUR LAST DECISION. YOU CAN MAKE GREAT PULLS WITH ALL TYPES OF TIRES. LEARN YOUR BALANCE AND PLAY WITH THE HITCH HEIGHT.
BlakeG
07-08-2007 19:48:32
 Re: Hey oliver guys in reply to KT4387, 07-08-2007 13:51:42
My set-up is hitch is set at 20 hieght and 18 from axle, i have 16.9-34 safemark tires with about 7/8" lugs, tried differnt air pressures has worked best with 7.5 psi in the 5500-6500 classes at 3.5 mph, as for weight i usually have it so at middle of pull front is about 3-6 inches up and at end its about 6-10 inches up, give or take of course, ive just notice most the tractors that are beating me have only about 1/2" to 5/8" of lug if that. any tips would be great!
77 Oliver
07-08-2007 10:37:17
I like the 14.9-38 Titan Hi Power Lug. However, if they will let you run a bigger tire, go for it.
JD hauler
07-08-2007 07:26:16
I have seen great success over all brands with armstrong tires, they seem to wear the best and wear sharp.
