vapor locking
ajdeereman
07-22-2007 19:05:36
I am having a problem of my john deere 60 that is running on regular unleaded pump gas vapor locking. Is there something I can do becides loosing the fuel cap.
mEl
07-23-2007 04:21:55
 Re: vapor locking in reply to ajdeereman, 07-22-2007 19:05:36
If vapour locking is truly your problem then loosening the fuel cap should not cure it, a plugged vent in the fuel cap causing a partial vaccum on top of the fuel supply prohibiting the fuel from gravity feeding the carb is different from vapour lock, a vaporizing of fuel in the lines/carb which also prohibits fuel flow. if loosening the cap cures your problem, clean the vent in the cap or replace it. if not find ways to keep the engine heat off the fuel lines, make sure they are not located near the ex system or manifold.good luck, mEl
