aluminum front wheels
bassndeere
08-03-2007 16:59:20
How do they put those nice aluminum front wheels on the pullers. Does anyone make a six hole front rim? Thanks
John in WVa
08-05-2007 01:26:34
 Re: aluminum front wheels in reply to bassndeere, 08-03-2007 16:59:20
There are several different six bolt style wheels, go to a tire/wheel store, Summit Racing Etc. You have several choices 15 inch x the width of the tire that you will use x back space. Use your hubs, offset the holes and redrill ,install studs, machine shop can do this. You may have to machine the center of wheel to clear bearing cap
JDH
08-04-2007 09:51:58
I changed the front and put boat trailer hubs that are ford bolt pattern and used regular aluminum wheels
bassndeere
08-04-2007 19:28:27
 Re: aluminum front wheels in reply to JDH, 08-04-2007 09:51:58
Thanks for the help JD H
I have considered that route. Did you have any problems with the bearings to spindle/hub mating up?
JDH
08-05-2007 04:36:34
 Re: aluminum front wheels in reply to bassndeere, 08-04-2007 19:28:27
No, I had no problem at all. I just searched for the same size as my spindles. There was about 5 lbs of weight savings per hub also
