need a little help on allis wc
buford
08-15-2007 17:54:50
we have done a lot to this ole wc at the pull last sat. we hooked in 3500 and pulled 130 ft.at that time we choked, dead stop. we have a wd45 crank wd45 rods, flat top pistons good compression, carb. is stock I feel like we are running out of gas what carb would work for us? we weighed in at 3590lb I checked the time today it is ok We used a d17 gov. spring is it to much?oh yes we were 4th out of 8 tractors 185ft.was 1st place we would like to be more competive we were placed in a farm modifed class this our 2nd pull thanks for any help. Hope I have not rambled to much
buford
08-16-2007 19:04:04
 Re: need a little help on allis wc in reply to buford, 08-15-2007 17:54:50
thanks guys, tank could have a little rust altho we cleaned it and lined it I do beleive we will try a micro fuel pump 2psi.I will go through carb. again I think gov needs to be looked at thanks again for all your help
RKEENE
08-16-2007 17:34:09
I had the same problem last week but with larger carb. Seems the float needle seat was clogged and the carb bowl couldn't refill fast enough.
jd plowboy
08-16-2007 16:50:23
the best money i spent on a wc was electronic ignition. mind has all the 45 stuff but it would stall in 4000 and 4500. after the ignition it would keep on going.
Jack a
08-16-2007 05:08:04
Do you have new points and plugs? Make sure the carb is syncronized to the governor. May have to use a 45 carb to feed the added stroke from 45 crank. WC does have an aweful fast 1st gear but with 45 powered engine shouldn't stall out in that light of a class.
LWD
08-16-2007 01:43:32
you might try to find a 5 tooth pinon gear. they did make them for the wc`s when they wanted to use a corn picker, use hytrans oil in the transmison,use the gove. weights for the 45 engine when it was used in the comebine(they are differant from the tractor weights)take the pto off, take the belt pulley off,take the cast wheel centers off,these things give you some thing to start with. I have seen wc`s in the 2600 lb class.
alliecat
08-15-2007 19:09:51
try retarding the timing till the engine just starts to lug make sure you have enough fuel getting to the carb I had a problem with rust in the tank and filter I changed to an aluminum tank mounted in the front weight bracket with a 5-7psi electric pump
just some "hard knocks " education
good luck
