Oliver 1850 Puller
1550 Puller
08-17-2007 18:21:17
How light can you get an 1850 Oliver diesel, assuming you take out the rock shaft, three point, and hydraulics. I will have to leave in the pto. This will be in a 3000 rpm hot farm/open class,
Super 77 Puller
08-19-2007 16:18:55
 Re: Oliver 1850 Puller in reply to 1550 Puller, 08-17-2007 18:21:17
Well if you loose the hydraulic unit, pto and put tin wheels on it along with a wooden grill you should have no problam getting into the 7500 lbs class. maybe even the 6000lbs class, you could buy an 1850 with no hydraulics or pto from the factory, just finding a stock hydraulic cover will be quite a challenge.
