4020 pullers
4020 puller
08-21-2007 07:29:06
How can you beef up a stock clutch to handle more horsepower? (running a 466 at 3500 rpms)
been there done that
08-21-2007 19:48:36
 Re: 4020 pullers in reply to 4020 puller, 08-21-2007 07:29:06
You are getting a little high on RPM's for stock parts. I tried running my gas 4010 with double spring pockets machined into the pressure plate. It made about 2 hooks, and I finally bought a 3 disk aftermarket clutch (all SFI Steel and alum parts). It seems that the stock parts give up in 6th gear or higher with any kind of RPM's. The stock pressure plate only uses a small portion of the clutch surface, with a few springs.
4020 puller
08-21-2007 19:53:30
 Re: 4020 pullers in reply to been there done that, 08-21-2007 19:48:36
someone once told me you could use the pto clutch with the engine clutch bolted together or something like that, have you ever heard of anything like that?
papuller
08-22-2007 05:04:26
 Re: 4020 pullers in reply to 4020 puller, 08-21-2007 19:53:30
I know that guys do that with the wet clutch, I suppose you could do that on a dry clutch???
