Summit MultiSpark
bm3501466
08-30-2007 20:27:23
I have a summit multispark ignition CD on my pulling tractor. It won't work right. All the wires are hooked up right, but it only sputters when I try to start it. Sometimes it pops like it is out of time. I think I may have a spark arcing somewhere under my cap. Any ideas?
als660r
08-31-2007 18:42:32
 Re: Summit MultiSpark in reply to bm3501466, 08-30-2007 20:27:23
My MSD6A works with the pertronix kit
Shawn W
08-31-2007 05:11:49
What are you using to trigger it, the litature i have says it wount work with a hall efect sensor. So i was reading some more and the way i understand it that the pertronix electric pickup is a hall efect pick up. I was going to order one but i would have to go back to points, the way i understand it. We hooked up a MSD 6A this spring with points and it really worked good on this pulling engine 15% hp increase and it really just runs better.
just a thought
Shawn
bm3501466
08-31-2007 06:46:17
 Re: Summit MultiSpark in reply to Shawn W, 08-31-2007 05:11:49
im using points as the trigger
Shawn W
08-31-2007 10:33:39
 Re: Summit MultiSpark in reply to bm3501466, 08-31-2007 06:46:17
Well ok,
i really dont know maybe try turning the distributor, it could just very well be outa time. good luck let us know if you get it fixed and how it works out, i would still like to get one cause it is cheaper then the MSD
just a thought
Shawn
