560 466
bm3501466
09-04-2007 18:10:29
I just bought a 560. I have a DT 466 sitting around as well. What's the next step. I scrapped the M idea. What has to be done to get the 466 in the 560?
Lee in Iowa
09-04-2007 21:42:51
 Re: 560 466 in reply to bm3501466, 09-04-2007 18:10:29
The last Farm Show magazine had an article about someone putting a 414 or a 436 in a 706. Since the 706 and the 560 used the same original engines and 414, 436, and 466 are all the same block there might be some good information there. I think the magazine has a website try googling it. Lee
just like cheatin
09-04-2007 20:32:07
You need to find a adapter plate and flywheel from a tractor that has the same bellhousing size and flywheel size as the 560. You can use the larger flywheels, but the starter won't work. Also, alot of the newer flywheels use a different style of starter ring gear, so you'll need to install a ring off of an m or 560 onto the diesel flywheel.
Super 77 Puller
09-04-2007 19:07:41
ive been told that if you take a 1066 adapter plate and bolt it to the 466 that it will bolt right into the 560. Im not sure i pull an oliver, i preffer 1rst place so i dont know much about the farmalls
bm3501466
09-04-2007 19:27:13
 Re: 560 466 in reply to Super 77 Puller, 09-04-2007 19:07:41
So I need a backplate off of a 766-1586 right? What about the flywheel? Where can I find a backplate in its lonesome?
