WC back together
AlanE
09-09-2007 18:43:17
Thanks to all for the insight and info over the past month.Finished it up Friday night and pulled Sat.No water problems and it didn't blow.It really ran well for the first time out.But,with 16.9 x 34 tires in the 5000lbs. it ran out of power.In 4500lbs. it spun out.I was wondering if there is a sherman tran anywhere for sale.
mlpankey
09-10-2007 21:36:38
 Re: WC back together in reply to AlanE, 09-09-2007 18:43:17
yeap vave lash cold 16 intake 18 exhaust 28 degrees total timing
AC
09-10-2007 06:39:17
Step up or down? Whats done to the motor?
AlanE
09-10-2007 15:40:48
 Re: down in reply to AC, 09-10-2007 06:39:17
Running 4.5 bore with 5in. stroke.Compression is 185-190lbs.Carb is off of a 460 IH.I maybe running the valves a little loose.I put them at .20 cold.The timimg also may need to be advanced alittle.
LWD
09-09-2007 19:23:47
Link
