WD45 Offset grind crank combo
AC
09-12-2007 05:49:34
anyone have suggestions? Have 4.5" bore already. Is there a truck piston that will work with the 2.0" Buda rods? thanks..AC
mlpankey
09-12-2007 19:49:12
 Re: WD45 Offset grind crank combo in reply to AC, 09-12-2007 05:49:34
NOT REALLY IT TAKES A CUSTOM TO GET ANY COMPRESSION THERE IS SOME LOW COMPRESSION MOTORS RUNNING 502 PISTONS 5.80 STROKE 2.0 COMP. HEIGHT MAKES 14.1 COMP. EASY
AC
09-13-2007 08:45:51
 Re: WD45 Offset grind crank combo in reply to mlpankey, 09-12-2007 19:49:12
Whats this starter deal you have spoken about before?
mlpankey
09-14-2007 13:04:24
 Re: WD45 Offset grind crank combo in reply to AC, 09-13-2007 08:45:51
i rework the windings were it will crank 14.1 or better compression ratio . i know it will start engines with 300 plus cranking compression.
