G-MAN
05-29-2002 16:04:11
Re: 4020 Deere Diesel in reply to John, 05-27-2002 18:18:18
I am not a pulling expert, especially when it comes to New Generation tractors, but I'll see if I can help you some on improving performance in a "stock" tractor. First of all, make sure your engine is in top shape - good compression, etc. Then make sure your fuel system is performing up to snuff - pull the nozzles and have them tested -if they're weak or faulty, replace or rebuild them. A guy can bump the opening pressures up some to increase atomization of the fuel and get better combustion, but I can't tell you the practical limit on that. Make sure your transfer pump is supplying the proper fuel pressure to the injection pump, as this can make a huge difference in power. Next, anything you can do to improve airflow into the engine will help, such as a good flowing air filter (shouldn't be hard to adapt a K&N or something to fit in the same location as the stock filter housing. Some head and manifold porting will also help, although not as much as turbocharging. A change may help also, but I don't know what's out there. Maybe a 4320 cam has more lift, being out of a factory-turboed engine. Air is the real key, because if you can't get the air in, all the fuel in the world won't make any more power - it just leaves the engine as black smoke. The ideal engine would make maximum power without smoking at all - as it would be burning all the fuel it was given completely and efficiently - but that is a hard balance to strike, especially in the old mechanical engines. The rule of thumb has always seemed to me to be over-fueling the engine, that way you're sure you're getting everything out of it. But if you have access to a dyno, you can make adjustments to your pump to maximize power without looking like a mobile oil-well fire. You're best bet may be to go to some pulls and ask the successful pullers what they've done, etc. And don't limit yourself to simply talking to Deere pullers - most of the tricks will work on any engine, regardless of manufacturer. Good luck with your tractor.
