John deere B
Ben Rauls
10-17-2007 18:47:42
Where would i find some higher compression pistons for my 1944 B? Not sure waht the bore is yet have to wait til winter to tear down. Is there anything i can do to the stock headfor a hp or 2?
Ben
Gary From Muleshoe
10-18-2007 13:49:11
 Re: John deere B in reply to Ben Rauls, 10-17-2007 18:47:42
Get a few for HPs and put a creeper gear in it, that will turn some heads.
EASYY
10-17-2007 20:16:34
If your bore is in really good shape the best way to go is lenthen your connecting rods to raise the compression, save money on boring the block, and on the piston purchase!
Dalton S.
10-17-2007 20:11:41
No offense to JD B, but a 2 cylinder is just not worth putting money into. You could spend a lot of money on a 2 cylinder engine and only get half of the horsepower you can get out of a 4 cylinder engine.
B-maniac
10-19-2007 18:12:29
 Re: John deere B in reply to Dalton S., 10-17-2007 20:11:41
It would be a pretty boring world if everyone just ran "Chevys". Unfortunately it takes knowlege AND money to win with a JD. Some just choose the "money" route and therefore must pull the "other" makes.
Gary From Muleshoe
10-18-2007 13:47:21
Dalton
Yeah, but they don't sound as good doing it. Here in W. TX & E. NM the JD's are hard to beat at a pull. Stock or modified.
730-LP
10-18-2007 11:44:19
I disagree I have an A John Deere that has 58 HP that will beat a 80hp M Farmall or an Oliver 9 out of 10 times. 6000#,6500#7000# 4 or 5 mile hr classes. Its not how fast you go but how far.
Ben Rauls
10-18-2007 01:40:19
I'm not out to win just be competative. Around here the A's and G's are about the best in the heavy classes, the b's do pretty well to in the light classes. I pull a oliver 88 diesel in the 7 and 7500 just want something different.
Ben
jd b puller
10-17-2007 22:02:53
That must be why there aren't any JD's out there... Division IV/V, yep I'd agree with you. Division II/III. Bring it.
AC
10-19-2007 05:15:04
 Re: John deere B in reply to jd b puller, 10-17-2007 22:02:53
You are from Michigan, arent you? If so, consider it brought :) ... They say a good diet includes an assortment of greens..j/k..AC
jd b puller
10-20-2007 19:29:15
 Re: John deere B in reply to AC, 10-19-2007 05:15:04
Hi AC, no, not from MI, I'm in NC now.
Pil Munson NY
10-18-2007 14:47:58
Hey Hey:
Did you notice that somebody had some really good looking 5.75" pistons for sale on the board!! Couldn't they be used in a B; if you wanted a little more starch out the putt putt. Do you know if the pistons are available in titanium yet? best Yeoman
jd b puller
10-18-2007 19:56:48
 Re: John deere B in reply to Pil Munson NY, 10-18-2007 14:47:58
If someone could show me how to link a picture, I'd show you the block those 5.75" pistons go in...
Ben Rauls
10-18-2007 16:54:03
I could go from 4.5 to 5.75 in the stock block right?
Ha ha
