Tires and Rims Needed
1256ih
10-21-2007 17:41:43
my class is changing the rules so that we can have 20/38 tires. right now i have 18/38s on IH pressed steel rims and i was wondering if 20s would fit on there. if not what are some options to do?
any help is appretiated,
kyle
ejr-IA.
10-21-2007 20:44:03
 Re: Tires and Rims Needed in reply to 1256ih, 10-21-2007 17:41:43
The 20 will fit but you should have the wider rim for the 20 so the tread will be flater on the ground for better traction.A 18.4 uses a 16'' rim and a 20.8 takes a 18'' rim.If rules allow I would use a little wider than 18 If you can.
