Question for WTW
alby15
11-09-2007 15:35:06
Another question,whjat is the lightest starter I can use on a 466 JD I see some gear red 11 tooth that say they work but am not sure? Any other weight reduction Ideas?
al
alby15
11-11-2007 16:59:36
 Re: Question for WTW in reply to alby15, 11-09-2007 15:35:06
could you get me an exact starter # when you get a chance? thanks al
WTW
11-11-2007 06:20:06
I like and use a direct drive Nippendenso found on allot of power units and I think it was also used on the 7000 series Waterloo tractors. The nose and back plate of starter are aluminum. Look similar to the older Nipp starter and quality and performance are the same but I would say they are about a third lighter in physical weight. They will crank fast and take allot of abuse.
