ChadS
11-21-2007 06:08:40
Re: G puller in reply to HOT FARM PULLER, 11-20-2007 14:47:45
Another G puller said: (quoted from post at 20:22:44 11/20/07) Before taking it apart, try running it on 110 racing fuel. The 110 or even 112 gas and checking the timing should stop the knocking. High comp. G's don't run well on regular gas. It's worth a try before going back into the motor again. |
Try a mix, of E85 (ethanol) and 93 octane pump gas. With higher cyl pressure, and an octane rating of atleast 105, but this stuff does the work of 120 octane in pure form,,, depends on what the cyl pressure test results are to know exactly how much to mix,, but with a JD 2 cyl with 180 psi at cranking speed, it would knock, could not shut it off,, that was on 93,, poured in a gallon of E85 right into the gas tank,, drained the carb and fuel lines, fired it up, readjusted the timing and th carb settings, and it runs like a dream. Lugs very hard and still no ping or knock. Try it! You might discover the power of corn. JMHO,, dont shoot the messenger, K? Have a good one! Chad
