ChadS
11-26-2007 06:38:12
Re: Farmall 560 carb. in reply to 560 puller, 11-26-2007 06:27:08
806 carb wont fit and look stock on a 560,,, they sit backwards. Find a 715 combine carb throttle body to replace the stock 560. depeding on the rpm range you want to run, say stock up to 10% over rpm, use a #33 or a #29 for best low end torque. For higher rpm operation, which really is where a 301 should be operating, (2800 rpm) use the #35 venturi. You may have to increase the jet size a few, but it will help for sure by using a 715 carb. The 560 carb, is primative,,, the newest design for the later model combines, say up to 1973, had the good carb. I have 4 of em if ya need one, I know I have a throttle body in good shape. If you find a 715 top half,,, set em side by side to the 560,, look down inside the throat,,, you will see more passages for fuel delivery in the combine carb, than the 560. They start easier, run smoother and have better torque. Hope this helps. ChadS ChadS3@hotmail.com
