jd b
ajdeereman
12-16-2007 09:47:12
what will i accomplish by putting a gas manifold and boring it 90 over on my 1943 all fuel JD b
jd b puller
12-16-2007 20:17:09
 Re: jd b in reply to ajdeereman, 12-16-2007 09:47:12
I'll second that. 0.090" overbore with stock compression won't make much difference. Upping compression to 11:1 would help. Stick a crank in there and it will come to life. 7" is easy (decent power, mimimal grinding, no hole in the back wall), 7.5" is a little harder (more grinding), and you can go bigger but it starts to be a real PITA.
smdv806
12-16-2007 09:54:12
not much, you need to stroke it and do some head work
