Super H handclutch for pulling
2superms
12-17-2007 00:23:02
Was woundering if anybody used a handclutch on h or m for pulling. was woundering if it would hold up.
2superms
12-17-2007 17:00:42
 Re: Super H handclutch for pulling in reply to 2superms, 12-17-2007 00:23:02
thanks for info was wanting my kids to pull a red tractor instead of a green tractor because they are still young (8) years old. thanks again
jhb
12-17-2007 16:40:54
I have one and it would always slip. I drilled 3 holes through it put in bolts and ground the nuts and bolts down so that they would clear. Works fine now. I was too lasy to pull it all out and replace the parts.
Ole Sow 53
12-17-2007 12:54:08
I pull a Super H with a M & W hand clutch.
I tighten the big nut as tight as I can with a punch and big hammer just before every pull;
but, it will slip if the pull is over 250-300'. You can forget about a second pull that day.
VOLfarmall
12-17-2007 11:27:59
They will not hold up for heavy pulling
Charles E. McNelly III
12-17-2007 07:51:08
If you were to use one, would it be able to put the left brake pedel on the same side as the brake? Just wonderin"
Charles
why
12-17-2007 03:57:01
Just kinda wondering what the advantage would be unless someone had a physical disability which made a foot clutch unfeasable. I could be wrong on this one but I didn't think the old M&W hand clutch was the most reliable thing on the planet.
