MW Pistons
2superms
12-21-2007 00:35:33
Was woundering if a early model m block could with stand 4.250 m&w pistons bare block no sleeves. Also woundering if anybody might have some.
1000yds
12-22-2007 16:36:42
 Re: MW Pistons in reply to 2superms, 12-21-2007 00:35:33
My 39 M is running 4 1/4" pistons in the bore. Works great! Spend some time with a good hone and it should be fine.
Charles E. McNelly III
12-21-2007 15:28:58
The only way to know for sure would be to get the block x-rayed, to see how thick the walls are, I don"t think so but you never know until you check. Find a block out of a Super M, power unit, 400, or 450.and then it"s a different story. I have heard that 4.500" or more isn"t uncommon with a good block. Good Luck
Charles
the real bigdaddy
12-21-2007 08:00:03
i have a complete motor with m&w kit stroker crank & pistons line hydrloics for sale if int call 800-553-5417
