clutch upgrade
460anger
12-31-2007 08:21:24
Have a Farmall BN that I"ve drastically modified the engine. I need to know who you guys have build your clutches. Please don"t tell me Denny"s Carb.!! Thanks.
ChadS
01-01-2008 08:42:38
 Re: clutch upgrade in reply to OLIVERKID, 12-31-2007 08:21:24
Fran Kopta said: (quoted from post at 09:02:08 01/01/08) chad,
trying to get up there with my vac.good hope to see you out pulling instead of in the stands.
LOL! Ol Shaggy has a real good BN. I have a Cub Low boy,,, taking up space. VAC case are pretty nice tractors! years ago, my cousin had one that would run 45 mph down the road!
Ed Hodge
01-01-2008 08:07:50
 Re: clutch upgrade in reply to 460anger, 12-31-2007 08:21:24
take you clutch to a shop the deals with heavy truck have the reline with four bronz pucks on each side have heavy spring in your ps plate
Fran Kopta
01-01-2008 08:02:08
chad, trying to get up there with my vac.good hope to see you out pulling instead of in the stands.
460anger
01-01-2008 09:35:53
 Re: clutch upgrade in reply to Fran Kopta, 01-01-2008 08:02:08
Fran, See you finally woke up!! Had her on the dyno, was pushing 61 horse at 2200 RPM. Hit the nitro button went to about 80 horse, clutch started smoking!!! Can't wait to go against that C-C-Case!! See ya!!!!! !!!!
ShaggyM
01-01-2008 11:32:40
 Re: clutch upgrade in reply to 460anger, 01-01-2008 09:35:53
You GOTTA let me know when you are going to pull that MONSTER!!
ShaggyM
12-31-2007 20:47:52
Get a Brass button clutch disk. They are not the smoothest to engage but they will hold the power.
What kind of power are you getting out of you BN? My B only has 32HP but its a lot of fun and I can whip a few C's that are around here! Shaggy
Charles E. McNelly III
12-31-2007 19:19:36
What do you consider drastic? Bored block with Super H sleeves,auto pistons with a 340 head? Some guys run the 154ci. hopped up motors in there B"s and don"t have any trouble. If you have that kind of power, your not going to be able to keep those little 9.5"s or 11.2"s hooked up anyhow. Good luck with whatever you decide. I myself need a stronger moter in my B.
Charles
buickanddeere
12-31-2007 09:00:38
I looked in the yellow pages and went to a clutch rebuilding shop. The original Spicer clutch didn't even even use a wide enough friction area to contact more than 2/3 of the pressure plate/flywheel area. There were three choices of friction materials too. Of course after going to max friction area and the stickiest friction material. It's a touchy feat of clutch pedal feathering to keep her from "jumping" while engaging. Reverse is probably worst while backing up to the sled. You may have modified the engine but where and how high is the torque peak? If the engine is now making 225lb ft at 2500rpm instead of 200lb ft at 1200rpm. Odds are the stock clutch is fine torque wise but needs balancing and a scatter shield. Or a billet flywheel.
