M Ignition Question
CPR
01-05-2008 07:59:55
Have any of you put a MSD or like distributor in an M? What part # did you use to make it all fit together correctly?
CPR
larrystg2
01-05-2008 12:54:03
 Re: M Ignition Question in reply to CPR, 01-05-2008 07:59:55
MSD 6. MSD has an excellent web sight with very good instructions. I bought mine on ebay used cheap. It is a very easy installation.
CPR
01-06-2008 09:25:51
 Re: M Ignition Question in reply to larrystg2, 01-05-2008 12:54:03
Yep, I know about the MSD 6AL and intend to use it with a variable timing module. I'm curious about the distributor itself. Is there an MSD one that will work, or am I limited to a Petronix kit inside an original IH housing?
CPR
superih
01-07-2008 13:44:30
 Re: M Ignition Question in reply to CPR, 01-06-2008 09:25:51
The pertronix will be more accurate, but if you use the points to trigger, you have to take out the condensor.
bm3501466
01-06-2008 11:08:49
Dont worry about the distributor. Make sure though the springs are good. Use a CDI box like the MSD and just use the points pick up mode to trigger it. No need in buying pertronix with MSD. MSD does everything you need and is far superior. If you dont want to spend quite as much money Summit Racing makes a digital CDI for $150. Just go to summitracing.com
